RV.Net Open Roads Forum: Fifth-Wheels: Cheap bicycle carrier
 > Cheap bicycle carrier
me.camper
Southern Maine
Posted: 06/20/12 10:40am Link  |  Print  |  Notify Moderator
Does anyone know if there is a inexpensive way to carry 3 bicycles when towing a fiver without using the rear bumper on the trailer?(too flimsy) don't really want to spend 400 bucks on a pin mounted carrier.
2005 GMC 2500HD 4X4 Crew Cab
6.0L,4:10
2011 Coachman Freedom Express 296REDS
WI Bowhunter
Shiocton, WI
Posted: 06/20/12 11:13am Link  |  Print  |  Notify Moderator
Will they fit in the trailer? You could set some blankets on the floor and lay them down. i know some who can still fit them in the bed of the truck somehow. They usually pack 2 bikes.
Keep the Shiny Side Up!">
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
nremtp143
Georgia
Posted: 06/20/12 11:39am Link  |  Print  |  Notify Moderator
Go to a local welding shop and have them make you a pin box carrier. I made mine myself for about $50 bucks then bought a rack from discountramps.com for $139.
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
RoyB
King George, VA
Posted: 06/20/12 11:44am Link  |  Print  |  Notify Moderator
My sister carries two bicycles and I notice one more would not matter between their slide area and the fridge in their Montana 5th wheel.
The couch in the slide area is also available to stack a bicycle on ..
They have been doing this for years...
Try it out before you spend a bunch of money for an outside mounting.
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
blangen
South Dakota... and everywhere.
Posted: 06/20/12 11:46am Link  |  Print  |  Notify Moderator
Wow... nice job, nremtp143! Even the bubble is framed in black. I'm betting you placed that to see it in the rear view. Nice job!
remoandiris
Posted: 06/20/12 11:50am Link  |  Print  |  Notify Moderator
+1. I have 2 bikes sandwiched between the 2 slides in my LR. Each is covered by a moving blanket I bought at Northern Tool. I would have no problem finding a spot for a 3d bike somewhere in my 5er.
Only cost involved was the moving blankets. If you have extra sleeping bags you don't mind getting ripped a bit, you could use them instead.
2011 GMC 3500 Dually
New to me 2006 Jayco Designer 38RDQS
2 Boxers and a Maine Coon
nremtp143
Georgia
Posted: 06/20/12 11:55am Link  |  Print  |  Notify Moderator
Thanks! Took ideas from several on here and the "DIY" forum and made my own. I did a write up on it called "Our new 5er bike rack" when I made it. Then had to weld on the upper tube to fit a platform rack for more room above my toolbox. I'm sure a welding shop can do the same. Started with an old 10" piece of I beam and cut, flipped it, cut off one flange, welded it, and put 2 $14 receiver tubes on it from Harbor Freight. I love that they are out of the way.
SoCalDesertRider
Arizona desert
Posted: 06/20/12 12:54pm Link  |  Print  |  Notify Moderator
Cheapest way would be to put them inside the trailer. Any other way would require buying or building a rack of some type. Could be a roof rack on top of the truck, or a front hitch and hitch mounted carrier, or a hitch on the rear of trailer and hitch mounted carrier, or a hitch on the pin box and hitch mounted carrier....
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
elkhorn98
Santa Rosa, California
Posted: 06/20/12 01:34pm Link  |  Print  |  Notify Moderator
With 3 bikes you could put one on a rv ladder bike rack and 2 on an over the spare tire rack. It attaches to the bumper in 2 places and is rock solid (no movement like a receiver type rack). Both these racks are not too expensive and work for me.
Elkhorn98
2010 GMC Sierra 2500HD 4x4 Duramax/Allison w/45 gal Transfer Flow Tank
RBW X16 Slider, Yamaha EF 2400iS
2007 Springdale 245 5th Wheel - E-Z Flex HD Suspension & Mobile Outfitters Shock Kit Upgrades
with Firestone Transforce Ht Lt 2357515 C tires
bigjettech
Bartlett,Il
Posted: 06/20/12 01:52pm Link  |  Print  |  Notify Moderator
I use a frame hitch on the back of my 5er to haul 2 kayaks with so I was looking for a way to take bikes also. I ran across a post from someone else and used his idea which works pretty well for me. I put the table inside down to the sleeping postion and remove the seat cushions. I istalled 3 of these on the wood seat panels. Cut short sections of 2"pvc pipe with the top section cut off for the rear tires to fit in and mounted them on the opposite side panel. They are very secure,more so than on a rear bike rack and they're inside. When we get to a destination I put the bikes outside and flip the seat panels over so the brackets face down and put the cushions back on. I carry 3 bikes this way, still looking for a spot for a 4th. Bumper mount racks and ladder racks are useless in my opinion for bikes, if you value your bikes or the lives of the people driving behind you. If you're gonna carry them on the back it has to be a solid frame mounted hitch and a GOOD bike rack that the wheels sit into or else they'll beat themselves to death. You'll find a lot who disagree with me on the ladder racks or bumper mounts, I see them on the road all the time. I try not to travel very long behind them. But that's just my opinion.
* This post was edited 06/20/12 02:01pm by bigjettech *
2006 Silverado 2500hd duramax 4x4 - with a few mods ">
2006 Cherokee lite 285b+ 5th wheel
