RV.Net Open Roads Forum: Class A Motorhomes: RVA Jacks on Monaco Units
 > RVA Jacks on Monaco Units
faucet1
Posted: 09/11/07 03:57pm Link  |  Print  |  Notify Moderator
Has anyone having a unit with the 3 point RVA Jack system experienced leakage of fluid from any of the jacks, and if so, what was required to stop/repair the leak. Perhaps some of you may have repaired either an RVA Jack or HWH Jack. If so, how much trouble was it, and was it basically just replacing the "O" rings. I searched the database for info on the RVA Jacks, but found nothing. HWH however, is well represented, but didn't see where anyone had tackled a repair job. Thanks for any constructive info anyone might be able to provide. Take care all.
David
2002 Monaco Diplomat 40 PST Triple Slide
Toad-88 Ford Mustang GT-Stick
David and Jean
Argosy24
MI
Posted: 09/11/07 04:40pm Link  |  Print  |  Notify Moderator
Call RVA, (760) 746-5732, they are very helpful. Mine look like they are swedged together, good luck.
Twomed
FL winters and then somewhere cool
Posted: 09/11/07 05:14pm Link  |  Print  |  Notify Moderator
If you need a new cylinder... ask them for a rebuilt if available, much less $$ [emoticon]
Happy Trails ">
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
DarkRubiTJ
Livingston, Tx.
Posted: 09/12/07 06:31am Link  |  Print  |  Notify Moderator
Check your pump and resevoir. Ours had 2 problems from the factory the cap wasn't screwed on completely and the actual coupling attachment for the line wasn't tightened completely.
dougrainer
Carrolton, Texas
Posted: 09/12/07 06:03am Link  |  Print  |  Notify Moderator
RVA was only a Monaco supplied product. They did not make or sell to anyone but Monaco. Sadly, Monaco discontinued RVA a few years ago in favor of Powergear jacks. RVA still supports the product and if you call the number listed from the previous post, they will tell you how to send one back for rebuild. Doug
faucet1
Posted: 09/12/07 08:50am Link  |  Print  |  Notify Moderator
After a new search of the database older than 12 months, I found someone who has made a repair to one of their jacks. I'm going to give it a try. If I fail, I can always send it back for a rebuilt/replacement etc. Thanks for your words or wisdom. Take care.
David
BG1811
Paducah, KY
Posted: 09/12/07 03:11pm Link  |  Print  |  Notify Moderator
Two of my three RVA jacks started leaking just out of warranty. I was at Monaco and ended up buying two new ones. The two leaking ones are still laying in my garage. Must question the quality of these jacks.
2004 Monaco Diplomat 40DST (Bath and half) - 2007 Mercury Mariner Hybrid FMCA F288615
AND Our Wonderful Norwegian Forest Cat, Mackenzie
Gary.
Yukon, OK
Posted: 09/12/07 03:42pm Link  |  Print  |  Notify Moderator
I have 3 RVA jacks on a 2000 HARNEY COACH Riata, and so far have had no problems with them at all! Good Luck.
larmcintsh
Rathdrum, Idaho
Posted: 09/12/07 04:21pm Link  |  Print  |  Notify Moderator
I have RVA jacks on my 1994 Monaco Dynasty. I have had since new. I have had no problems with the jacks. Just replaced one valve. They are very helpful in dealing with any problems.
I rv
Westerly,R.I.
Posted: 09/12/07 05:11pm Link  |  Print  |  Notify Moderator
If your jacks are just seeping don!t be afraid to try one of the transmission stop leak additives.These products soften seals and really can!t hurt anything.I have had good luck using these products on various hydralic rams including marine tilt cylinders and within days no oil slick on water 100%fixed cheep and easy.[emoticon]
