RV.Net Open Roads Forum: Class A Motorhomes: Hot water issue
 > Hot water issue
wilsongulf
North Port, Florida
Good Sam RV Club
Posted: 07/26/09 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I am having a strange issue with our hot water. The cold tap in the kitchen and bath work fine but when we turn on the hot water tap no water comes out. Any ideas.
Thanks,
John
robsouth
Near Atlanta, GA
Good Sam RV Club
Posted: 07/26/09 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Check the winterizing by pass valve to be sure it is in the correct position.
Dodge Ram 3500 Cummins Turbo Diesel Dually
Terry 22U
Regal 1900LSR
"Great minds like a think"
wilsongulf
North Port, Florida
Good Sam RV Club
Posted: 07/26/09 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
robsouth,
Checked that, no problem there
Ritglor
Warren, RI
Posted: 07/26/09 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have a bad check valve. Had the same problem this past winter and had to replace the one on the outlet side of the tank.
Richard
Anml_341
Ontario
Posted: 07/26/09 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe an odd question but do you have water in the hot water tank and is it hot?
Frank Spence
Ontario Canada
Member: Explorer-RV Club (Canada)
Member: FMCA #F275853
We invite you to check out our websites:
A) General happenings in our lives
B) Articles & book written and published:
Email:frankspence@hughes.net
javaseuf
California's Gold Coast
Posted: 07/26/09 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
What about the other hot-water faucets? If you still get hot water in the bathroom, it won't be the check-valve.
Steve
2007 Springdale 291RKL
2009 F150, 5.4 ltr.
1986 Palomino Hard-Side PUP
"Nobody knows how we got to the top of the hill, but since we're on our way down, we might as well enjoy the ride". ("The Secret Of Life", James Taylor).
Artum Snowbird
Campbell River, B.C., Canada
Posted: 07/26/09 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Just to check the lines, put the bypass valve in the other position, and then try the hot water taps... If water (cold) comes out, the taps are fine, but your hot water tank is not letting water through.
Mike
Mike and Carole
2006 Triple E Regency 27 foot SXL
2005 16.6 Double Eagle
Mizzouri
Missouri/Arizona
Good Sam RV Club
Posted: 07/27/09 10:02am Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue and it was the check valve problem. The valve is generally on the backside of the water heater. It can or cannot be a problem getting to the valve to change. When I found the problem I replaced both valves even though only one was bad. It was cheap insurance and piece of mind that I don't have to replace later.
2004 Horizon 40'
2004 Honda CRV
brobox
Sunny SW. Florida
Posted: 07/27/09 10:15am Link  |  Quote  |  Print  |  Notify Moderator
If you have an outside shower, check to make sure the faucets are shut off and not just at the head of the shower. Common problem.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
BWhite
Metrowest,Ma
Good Sam RV Club
Posted: 07/27/09 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Check your outside faucets to see if they are off.
Make sure you do have hot water in the tank .
Then see if the mixing valve at the hotwater tank outlet is working correctly
I had to buy a new mixing valve from Atwood
Bill and Patti
Gizmo a Black face Tri-color Pembroke Welsh Corgi
Laci a Red and White PWC
06 Fleetwood Revolution LE 40E
05 Hyundai Elantra Toad
Member, Revolution Owners Group,FMCA,CAT RV Engine Owners Club
www.revolutionmotorhome@yahoogroups.com
 > Hot water issue
