Does anyone know which type of refer draws the less amount of battery juice? I always thought cooling in the gas mode would draw less battery while boondocking vs operating off 12 volt mode?
1992 jeep cherokee 4x4-158,000
2006 jeep crd 4x4-36,000
2008 Chevrolet Cobalt-28000
2009 Dodge Ram Hemi 4x4-900
2009 TaDa TXL-sold on Ebay
2010 Lance 1880 on order
days camped 2008-22
days camped 2009-37
12v mode wears the battery down quickly. In gas mode, which is what I use, the battery is just running the control board, and will not run down unless you use it for other things. As long as I have propane, the ref runs.
As an aside, if you know you're going out for a long trip, freeze a gallon of water and put it in the ref. Reduces the load on the unit, and after it melts, you have drinking water.
K1BE Jeff
Vulneratus Non Victus
"Wounded but not Conquered!"
The refer needs a very small amount of DC to operate the controls. Without that it will not run at all. The propane mode takes much less power than the 12v mode to operate the cooling cycle.
Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
12 volt is usually used ONLY for very small fridges and even THEN basically to MAINTAIN cold rather than create it. Different purposes involved in the two.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles) Rockwood 8314SS 34' travel trailer
The 3way I had in my PUP had no 12 volt control. The cooling power was manual so in propane mode there was no battery required and no drain on the connected battery. Two way seem to all have an electronic control and need 12v to hold the propane valve open.
Propane mode will always have the least draw on battery. Of course plugged into power it does not matter.
