RV.Net Open Roads Forum: Tech Issues: Ceiling Fan MaxAir Cover
 > Ceiling Fan MaxAir Cover
Tech Issues Related Tips
NorCal Dan
BAFB FamCamp (California)
Good Sam RV Club
Posted: 10/31/09 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have been wanting to install covers on my roof over the fans so I bought 2 MaxAir covers from Camping World. When I tried to install them I found out that I can't install the brackets, my fans have a double-wall making it impossible to get the nut on the bolt. Anybody else run into this issue and find a solution?
'08 Monaco Diplomat SFT being pushed by '07 Jeep Wrangler
-- USAF Retired --
FLY 4 FUN
Alberta
Posted: 10/31/09 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
I am pretty sure mine were the same way. You have two choices
1. purchase a longer bolt and drill through until you can put on the washer/nut
2. use a small pilot hole, and then self tapping screws that wont go in too far.
Daryll
2009 Colorado 29BHS M5
08 Dodge Ram 3500 QC SB 4x4 CTD 3.73
Prodigy BC Reese 16K slider
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
jeepsucks
ontario
Posted: 10/31/09 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have the create a breeze fan. From the inside you can unscrew the plastic shield. With this removed you can put the nuts on the bolt. Hope this helps.
DW, Me, DD and new DD!
"Life isn't like a bowl of cherries or peaches, it's more like a jar of Jalapenos--what you do today, might burn your butt tomorrow......"
You can't take the Fisherman out of this Camper
Ontario, Canada
Good Sam RV Club
Posted: 10/31/09 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a ShurFlo Fan and put the nut on the inside before installing the plastic insert on the inside.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS & 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
NorCal Dan
Good Sam RV Club
Posted: 10/31/09 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
I tried coming in from the bottom, but I am unable to reach the area where the bolts will come through the case. They fan is an assembly, I see no way to even take it apart, it looks like it is a single sealed unit. I will take another look at it tomorrow but I don't think I can take it apart as there were no visible seams.
bb_94401
San Mateo, California
Posted: 10/31/09 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
What type of fan do you have? On my original fan the dome cover was just screwed into the metal sidewall.
I replace that with a Fantastic fan. I had to remove the ceiling flange from the inside and then remove the knobs and switches to remove the lower plate to see where the bolts would come through. It was so close to the upper surface of the fan, due to its low profile, so a nut would not fit there. I glued in pieces of ABS plastic to give the screws more to anchor themselves into, drilled small pilot hole and screwed on the mounting brackets.
See my pictures at the end of this thread Fantastic Vent 4000 (no reverse) & MaxxAir Vent Covers
* This post was last edited 11/04/09 12:04am by bb_94401 *   View edit history
San Mateo, CA
'05 Ram 3500, 4x4, DRW, LB, 6spd man, CTD, PRXB exhaust brake
'01 Corsair 10'8" - 4,200 lbs., Xantrex XADC 80A, Link 20, 4-Lifeline GPL-4CT, PowerGate Isolater, 2 AWG wire, PI 30A EMS, 2 Honda EU2000i, parallel kit, ext. duration tank.
Deen
Vancouver, WA
Posted: 11/01/09 12:39am Link  |  Quote  |  Print  |  Notify Moderator
I installed a MaxAir II on one of our Fantastic Fans. I used short, sheet metal type screws. Drilled the holes, filled with sealer and put the screws in. Works fine.
NorCal Dan
Good Sam RV Club
Posted: 11/01/09 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I don't know what type of fans Monaco installed on my coach. They are listed as "12V Attic Fan w/ Auto Dome" on the window sticker. I don't know what they mean by auto dome, but the cover has a motor that will open/close the cover, or you can pull on the handle and manually raise/lower the cover.
Thanks for the pictures of your install. If I can figure out how to get to the inside of the wall where the bolts will come through so I can add reinforcement to the plastic I could do something similar. I will have to see if I can remove the fan assembly enough to gain access.
Roger10378
Goodrich, MI.
Good Sam RV Club
Posted: 11/02/09 07:59am Link  |  Quote  |  Print  |  Notify Moderator
My MaxAir's came with a short sheet metal screw. I drilled a small piolet hole and screwed the brackets to the fan. So far everything is great.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Clay L
Sioux Falls, South Dakota
Good Sam RV Club
Posted: 11/02/09 10:18am Link  |  Quote  |  Print  |  Notify Moderator
That sounds like a Fantastic Fan. If so it will come apart so the nuts can be put on. I did it with mine when I installed my MaxAir hinged cover.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
