RV.Net Open Roads Forum: Forum Technical Support: boondocking arizona (retry)
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > boondocking arizona (retry)
Forum Technical Support Related Tips
timdog
mesa, arizona
Posted: 11/08/09 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Becky tim
tabby and max
twin honda 3000is
prowler 25 rls extream edit.
2006 titan 4x4
jefff929
Pacific wonderland, wet side
Posted: 11/08/09 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
how is this?
press quote and you will see the code.
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 11/08/09 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
You are using the wrong URL.
Here is a tutorial for you.
Posting pictures using Photobucket.Com as the Host Site.
There are lots of tutorials in the stickies at the top of this forum.
Please do not start a new thread each time you want to test the same concept. Instead, add a new post to the thread by clicking on the Reply to Topic link. That keeps all of the attempts together and makes it much easier to help you.
I have deleted the other three threads.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
timdog
mesa, arizona
Posted: 11/08/09 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
thanks tom i have read alot of the post about this and still cannot get it, i will read yours thanks again
Becky tim
tabby and max
twin honda 3000is
2006 titan 4x4
timdog
mesa, arizona
Posted: 11/08/09 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Moderator's edit: reduce the widths of the pictures to the forum's recommended maximum of 640 pixels .
* This post was edited 11/08/09 07:08pm by an administrator/moderator *
Becky tim
tabby and max
twin honda 3000is
2006 titan 4x4
timdog
mesa, arizona
Posted: 11/08/09 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
i think i got it thanks all..
Becky tim
tabby and max
twin honda 3000is
2006 titan 4x4
Golden_HVAC
Fulltime, CA, USA
Posted: 11/08/09 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
You need to edit your post to reduce the size and width to the pictures that you posted. It needs to be less than 500 wide to fit on the screen of a normal computer.
Remember the pictures are probably 5 x 7 " so if you keep the same ratio, then about 350 high and 500 wide is the correct ratio. When you put in the picture, it will ask for a height and width.
Good Luck,
Fred.
Brodie3Az
Chandler, Arizona
Posted: 11/08/09 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hello TimDog,
Are these the Superstitions near Florence Junction?
timdog
mesa, arizona
Posted: 11/08/09 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Brodie3Az yes it was out on the paralta rd about 3 miles from the trail head.
Becky tim
tabby and max
twin honda 3000is
2006 titan 4x4
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 11/08/09 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Please go back and read the part of the tutorial about picture size. I have reduced the sizes of the pictures you posted to the forum's recommended maximum of 640 pixels.
Tom
