RV.Net Open Roads Forum: Class A Motorhomes: Mapping Software
 > Mapping Software
Stuck in first
Virginia
Good Sam RV Club
Posted: 11/09/09 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
What mapping software do you use?
I use microsoft streets & trips and am disappointed with it.
I cant edit the names of the way points. It would nice to not see I-20six times in a row. Can you edit the names in any other software?
Diplomat Don
Moorpark, Ca
Good Sam RV Club
Posted: 11/09/09 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Stuck in first....As you create your stops on the left side of the "Street & Trips" window (add to route) edit them there. Pick one of your stops, right click, and it will let you rename the stop.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
RicJones
So. Cal.
Posted: 11/09/09 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
I use S&T, DeLorme and Trailer Life campground CD. All for different reasons. To me S&T is the easiest to use. If I could only have one it would be the Trailer Life.
scottmohr
jupiter fj
Good Sam RV Club
Posted: 11/09/09 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
T use S&T, and trailer life,like S&T best
kix
Racy Point, Florida USA
Posted: 11/09/09 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
I use DeLorme Street Atlas and Topo when in mountainous areas. We also have Trailer Life CD. My only complaint about Trailer LIfe is that the roads are a little difficult to distinguish on their software. If the roads were darker or bolder I would use it more. Anybody konw how to address this issue with Trailer LIfe??
KIX
'02 Winnebago Ultimate Advantage
350hp Cummins ISC
'06 Jeep Grand Cherokee Limited
5.7 L HEMI
wny_pat
Western NYS
Posted: 11/09/09 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Can the Streets and Trips be upgraded? I see S&T 2006 w/gps advertised for only $44. If you buy that, can you upgrade it as part of the program, or is it like the different Windows and when they quit supporting them?
RicJones
So. Cal.
Posted: 11/09/09 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
I see S&T 2006
2006??? I picked up 2009 without the gps at Sam's Club for about $20.
Stuck in first
Virginia
Good Sam RV Club
Posted: 11/09/09 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have S&T 2007. I tried the right click on the Route planner. There is no option to edit. You have to put a correct address in and once you click ok the address appears with a number. Once in the box you cant edit it
garym114
Posted: 11/09/09 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Each year of S&T is a version. If you want to upgrade you get a later year. You can use just about any GPS receiver with S&T. I have used a bluetooth GPS with two different versions.
Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
garym114
Posted: 11/09/09 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
You probably need a later version to edit the names of the stops.
 > Mapping Software
