Hardtack
How about your front yard.....
That's why they make a 50A to 30A adapter.
In the past 2 1/2 years we have used the adapter more times than straight 50A with no problems.....1 A/C, microwave, water heater, coffee maker, electric skillet, TV, DVD, Radio, lights etc.
Dual A/C's at the same time with high draw appliances will trip 30A breaker, otherwise OK.
Enjoy your new 5'vr and your trip in December.
2007 Dodge Ram 3500 CTD Auto Quad Cab SRW Long Bed
2007 HitchHiker II 32.5 UKLG
1 Happy Girlfriend
1 Mean Dog
Fulltime RV'ng & loving it
The difference between genius and stupidity is that genius has its limits. Albert Einstein
ML
Livingston TX
A couple of years ago we were in a park that was "unique", first time we ever needed an extension cord to be able to plug in. Off the to RV store in town. The weight of the 50 amp cord is a pain so when we saw this 50-Amp Locking Adapter with 25' 30-Amp Cord marked 1/2 price it was a no brainer. We haven't used it very often since but occasionally when we are jut overnighting it is easier to use than the 50 amp and we always have and extension cord if we ever need it again.
ML
SteveRankin
Sequim, WA
Our DP had 50A service and a zillion things to run on the 100A you actually get from 50A RV service. We probably had 30A service more often that 50A though, so we just made the necessary adjustments in how much stuff ran simultaneously.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 24-5N
2007 Ford F350 4X4 Crewcab LB 11.5K GVWR
PullRite 18K SuperGlide
Our Arctic by RV trip
Our Beaver motorhome Technical page
The Arctic Circle
Tom_Diane
Luzerne IA
When we bought our 5er we also bought a meter that plugs right into an outlet that will tell you at a glance if your over amping or under amping. Its pretty straight forward, if its in the green area your fine get into the red area or near it, it is time to cut back on some electric somewhere. Twenty dollar item and looks just like a multi meter. stays plugged in all the time. We put ours by the televison so we can just glance at it from time to time and know how much juice we are pulling or not pulling.
buc1980
houston tx
Tom where did you buy that device to tell you the amps you use?I like to have one too.
2003 Dodge 2500 ,2005 Kountry Star 35ft,Breaksmart controller,Equa-Flex.
WellShooter2
SE New Mexico
Good Sam RV Club
I don't think you can measure amps out of a wall plug. The amp measurement has to be at the power source. You can watch voltage at a wall plug but not amps.
2008 2500HD D/A
2008 Keystone Challenger
mynetdude
Grants Pass, OR
since we'er talking about 30/50 amps here... alittle off the topic somewhat, if I want more info I'll start a new thread otherwise.
Is it possible to upgrade from 30A to 50A? And how?
USA in a Chevrolet
Manahawkin, New Jersey
Good Sam RV Club
mynetdude wrote: since we'er talking about 30/50 amps here... alittle off the topic somewhat, if I want more info I'll start a new thread otherwise.
Yes, you'll need a new circuit breaker box, #6 wire form the box to the outside of your fiver & a new receptcle on the fiver as well as new 50 amp cord to rv pedestal.
