RV.Net Open Roads Forum: Hybrid Travel Trailers: water damage repair question?
Open Roads Forum  >  Hybrid Travel Trailers
 > water damage repair question?
Hybrid Travel Trailers Related Tips
Rescuebub
Relaxing in MD
Posted: 11/11/09 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, I know many people have had experience with water damage and I have a question. I am in the process of repairing my damaged floor, and upon pulling back the vinyl, I discovered that the wood is still damp. I repaired the leaks atleast a month ago, and I am wondering if the dampness is normal, due to not being able to dry under the vinyl, or should I search for more leaks? Thanks for any help and advice!
2002 Roo RLT25FDS
2008 Silerado 2500HD 4X4 Z71 6.0L, 6sp.
Me,DW,DD,2 Pups
struckrk
kissimmee
Posted: 11/11/09 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
There is alot of people here that will be able to help you better than me,but that sure seems like a long time to still be wet.
2007 Ford Explorer W/ Factory Tow Package
2010 Rockwood Roo 21SS
Reece Dual Cam WDH
TURK2500
Posted: 11/11/09 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Rescuebub wrote:
snip....or should I search for more leaks?...snip
If it were my TT, I would want to insure that all possible leak sources have been accounted for before investing in the repair(s). I would find an RV dealer that has an RV leak testing system (link) and have them run a leak test. This is the most effective and fastest way to put the issue to rest.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
RPFAN
Poughkeepsie NY
Posted: 11/11/09 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
You can also run one or more dehumidifiers inside to help dry it up. If it can't breath, it can't shed the moisture.
Rich
Rich, Fern, Bethany, Justin. 2005 Ford F450,Lariat, 6.0 PSD,CC,DWR,4WD, Air Hitch, 100 Gallon Aux fuel tank.
2009 Cardinal 3802BH 5 slide, 2 bath
Our "Condo in the Woods"
Leave no roller coaster unridden!
crab80
Virginia`s Eastern Shore
Posted: 11/11/09 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
It is very possible that it would still be wet well after you have fixed the leak. Until you remove the vinyl there is no where for the water to go and the area remains wet. Dry the area with a fan and then retest the repaired area (with a water hose) for leaks and see if the floor remains dry.
2010 Jayco 28BHS
2004 Chevy 1500 Ext.Cab 5.3L, 3.73, Bilsteins
Reese Dual Cam
Prodigy P3
Barker 3000 jack, 22 Blue tote
1kennyOG
Toronto
Posted: 11/11/09 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
TRUE. I'm a water damage tech and that is what I would do. Call a restoration company and rent an extra large Phoenix or Dri-Eaz dehu from them for 3-4 days.
Rich
2007 Kodiak 214 HTT
Rescuebub
Relaxing in MD
Posted: 11/12/09 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you very much for your replies! I'm always amazed by the amount of diverse knowledge found here. I'm going to try the dehumidifiers and then retest all the seams. It's currently raining here for the next couple of days, so it shouldn't be too difficult to see if any leaks remain. Thanks again
-Bob
