RV.Net Open Roads Forum: Class A Motorhomes: performance chips ford V10
 > performance chips ford V10
richard_123
new bern, nc
Posted: 05/31/11 04:02am Link  |  Print  |  Notify Moderator
looking at adding a performance enhancement chip for my Ford V10-30 valve engine in Class A motorhome. Found a company in South Carolina that does this. The company name is "5 Star Tuning". Has anyone had experiences with this company.
n7bsn
Yes
Posted: 05/31/11 08:19am Link  |  Print  |  Notify Moderator
There are many firms selling V10 chips, while I don't watch the market closely I've never heard of this firm.
If I was looking for advise on the V10 Chipping, I would go over to the Ford-Trucks Superduty forum and ask (it's the same engine)
Forum
What are you after, economy? power?
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
goodcruisin
Greenwood, IN
Posted: 05/31/11 01:58pm Link  |  Print  |  Notify Moderator
A chip on it's own won't do much to the V10 without first correcting the horribly designed exhaust, including the "Y" pipe. I know they are expensive but check into the Banks Power Pack System.
John (USN Ret) & Debbie
Tux (Amstaff/Dalmation mix)
'96 Monaco Windsor 36' DP 8.3 Cummins for chillin'
985 HP Dragster for thrillin'
fpresto
Maryland
Posted: 05/31/11 02:46pm Link  |  Print  |  Notify Moderator
Most chips for a gas engine require the use of premium fuel for very little gain in HP or torque. Check before you buy. It will also void any power train warranty you may have.
USN Retired
2016 Tiffin Allegro 32 SA
n7bsn
Yes
Posted: 05/31/11 04:22pm Link  |  Print  |  Notify Moderator
On another forum, the owner of one of the firms that sells V10 chips plan says that if all you do is chip, you will not be happy. He will sell you one anyway, but warns buyers.
jolooote
Miami, FL
Posted: 05/31/11 04:23pm Link  |  Print  |  Notify Moderator
Ford has squeezed about all it can from the 362 HP, 30 valve, V10. The only real improvement would be to get rid of that STUPID, extremely hot exhaust, Y junction near the engine. If its a Motorhome, u may be able to get rid of the Cat.Converter in states without emissions tests. If U do these 2 things and add a BIG breathing intake filter a chip probably won't do any better.
Joe & Charlotte, 2015 Thor Vegas 24.1 Ford E-350 305hp V10 5speed, Jeep Wrangler & Honda Element 'TOADS'
Rosie, Morky Dogs
Leroy's a Conure
"Once it starts breakin'...GET RID OF IT!"
koda55
Jacksonville, Florida
Posted: 05/31/11 08:59pm Link  |  Print  |  Notify Moderator
I have the 5 star tuning on my 2005 f53 20 valve. I also have the new y pipe that removes the restriction. I average 8.3 mpg towing a 3200 lb hhr. I recommend that you call Mike at 5 star tuning and talk to him. He is a straight shooter and very knowledgeable.I have the 87 performance tune. I donot have to use higher octane gas. Mike has many different tunes for rv's. You do not need to use the higher octane unless you want to. If you go to the ford heavy duty site you will read many accolades about 5 star tuning.
