RV.Net Open Roads Forum: RV Wash/Brush With Soap Dispenser by Carrand From Costco
 > RV Wash/Brush With Soap Dispenser by Carrand From Costco
ShovelNSwat
Posted: 08/25/11 04:56pm Link  |  Print  |  Notify Moderator
This is just a heads up. Bought this at Costco to wash/wax RV. Looked pretty sturdy. Just used it. Took it out, hooked up hose, turned hose on, lifted brush to side of RV, did one stroke up and one down and --- handle broke off. So I got drenched and washed instead of RV. Inspected handle. It was attached to a metal piece on the Brush/pipe by a mechanism with two plastic tabs. The plastic tabs had broken off about 1/3 in on each side.
I contacted the Carrand Co. by e-mail and described above. They replyed and are sending a new handle at no cost. I told them it was a good brush with, my opinion, an engineering defect.
The brush and pipe was great. I told them I can't believe they would use a cheap plastic connector and that I was going to post this experience. I suspect I'm not the only person this has happened to. The tabs should be metal.
JayWalker2009
I'm not really a
Posted: 08/25/11 05:01pm Link  |  Print  |  Notify Moderator
Kind of the same thing I think about those tent stakes that look like big nails - they go into hard terrain great! But they attach these pitiful plastic hooks on top that almost always break when you go to pull them out!
That never made sense to me, much like what you refer to in your post. PUtting strong materials in part of a product, and cheapo plastic in areas that will be stressed - just plain stupid.
Bucky Badger
Madison, WI
Posted: 08/25/11 06:08pm Link  |  Print  |  Notify Moderator
So you are getting another one to break[emoticon]
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
Taplep
Lawrenceville, GA
Posted: 08/25/11 06:13pm Link  |  Print  |  Notify Moderator
I just came back from Costco and I was just looking at that!! Sam's Club has one too and I was going to compare them. Thanks for the info.
2010 KZ Sportsman S272BH
2010 Toyota Tundra Double Cab
wmoses
Houston, Texas, USA
Posted: 08/25/11 06:51pm Link  |  Print  |  Notify Moderator
I have never had a good experience with brush-dispenser combos, and this experience by the OP is typical of what happens. A hose and pail with broom is the much better, and now I have a power washer with a fan setting that I can use to spray down with water or soap.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
MickeyBrennan
Playa de Carmen, Q.R. Mexico
Posted: 08/25/11 06:56pm Link  |  Print  |  Notify Moderator
We were looking at that product last week. Now, with more information that purchase will be reconsidered. Sorry you had trouble but...
Thanks for sharing your experience!
Blog
NC-Hawk
South
Posted: 08/25/11 06:58pm Link  |  Print  |  Notify Moderator
When going by a truck stop next time, check their store. They sell some heavy duty brushes with extension sticks (for cleaning their rigs). I've had mine for years, reliable and still works great.
Now as for the soap dispensor, I'm still using the old 5-gal plastic paint pail. [emoticon]
Socalz
So Cal
Posted: 08/25/11 07:09pm Link  |  Print  |  Notify Moderator
I thought this brush would be useful in washing my trailer, but I ended up busting it on it's second use. I noticed that the end was secured to the unit by a plastic connector and consciously tried NOT to grab the handle by the very end, but when reaching across the roof with the brush, it's only natural to grab it by the end. It's got a good brush and the extendable aluminum pole is pretty sturdy, but the product is only as good as it's weakest link which is obviously the crappy plastic connector.
NC-Hawk
South
Posted: 08/25/11 07:28pm Link  |  Print  |  Notify Moderator
Three Piece Fiberglass & Aluminum Extension Handle
The above is what I purchased at a Flying J truckstop years ago. Very durable and almost every screw-on brush will fit it.[image]
revump
Deer Park, WA or Las Vegas, NV
Posted: 08/25/11 07:31pm Link  |  Print  |  Notify Moderator
Sounds great ... I will look for this item
Bob
