RV.Net Open Roads Forum: Class A Motorhomes: Batteries, diesel class A
 > Batteries, diesel class A
frederick w
Wenatchee, wa
Posted: 10/01/11 07:29pm Link  |  Print  |  Notify Moderator
How many starter and house batteries are there
in a diesel motor home? For xample, a 95 Beaver
and or a 98 Holiday Rambler.
Thanks in advance.
2000 Fleetwood Flair
* This post was edited 10/01/11 07:57pm by frederick w *
wolfe10
Posted: 10/01/11 07:35pm Link  |  Print  |  Notify Moderator
Varies considerably.
Variables for chassis battery(ies):
Engine size and therefore starting amp requirement.
Size of batteries-- 8D's are common and a LOT bigger (size and capacity) than a couple of smaller 12 VDC batteries.
Variables for house battry(ies):
Inverter or no inverter.
If inverter w/wo compressor-driven refrigerator.
Size of batteries-- range from pairs of 6 VDC golf cart batteries to pairs of 8D's.
Brett Wolfe
2003 Alpine 38'
wny_pat
Western NYS
Posted: 10/01/11 07:45pm Link  |  Print  |  Notify Moderator
Thanks in advance.
Are you wanting to know about you 2000 Flair specifically, or motorhomes in general?
“All journeys have secret destinations of which the traveler is unaware.”
Mandalay Parr
Phoenix, AZ
Posted: 10/01/11 08:01pm Link  |  Print  |  Notify Moderator
Mine has two 12volt for the starter, and four 6volt for the house.
* This post was edited 10/01/11 08:09pm by Mandalay Parr *
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
pianotuna
Regina, SK, Canada
Posted: 10/01/11 08:18pm Link  |  Print  |  Notify Moderator
Hi,
Usually 2 starter batteries.
House batteries anywhere between 2 and 10
Regards, Don
Full Time in a Kustom Koach Class C 28'5", 256 watts Unisolar, 556 amp hours in two battery banks telecom AGM 12 volt batteries, Magnum 3000 watt hyvrid PSW inverter.
Patty98311
Missouri
Posted: 10/01/11 11:17pm Link  |  Print  |  Notify Moderator
My 2000 Country Coach has 2 8D batteries, my 94'Allegro DP had a single Group 27 battery.
2000 Country Coach
msmith1199
Central, CA
Posted: 10/01/11 11:30pm Link  |  Print  |  Notify Moderator
Thanks in advance.
I have two chasis batteries and four house batteries.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4
RognBon
Roseville, Calif.
Posted: 10/02/11 12:10am Link  |  Print  |  Notify Moderator
Our '97 dynasty has one 8-D starting battery (1400 cca) and two 4-D house batteries.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
GMC_jon
Arizona/Virginia
Posted: 10/02/11 12:33am Link  |  Print  |  Notify Moderator
My Foretravel came w/ 1 8D engine battery & 2 8D house batteries.
I found that the house battery area {2 8D's} would exactly accommodate 6 golf cart
batteries with a net gain of 260 AH for the house. The 2 8D's were 400AH rated (200AH ea) & the 6 golf cart batteries are 660AH.
The price difference between the two setups was less than $30.00! Of course cabling for the golf cart setup is additional.
I retained the single 8D engine (chassis) battery.
FWIW
John
slemnah
none
Posted: 10/02/11 05:38am Link  |  Print  |  Notify Moderator
Mine has 2 12v batteries for the chassis and 4 6v batteries for the house.
1997 HR Imperial
© 2016 CWI, Inc. © 2016 Good Sam Enterprises, LLC. All Rights Reserved. | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
