RV.Net Open Roads Forum: Technology Corner: No power to Directv dish
 > No power to Directv dish
JoannBob
Posted: 04/07/12 08:32am Link  |  Print  |  Notify Moderator
We just bought a rv dish setup from Satellite Oasis. Got it all hooked up but no power showing on inline meter. Worked on phone forever with Directv but still nothing. Had to put together the dish. It has 3 lnbs. Ran coax from dish to meter to receiver. Nothing. Any suggestions?
2011 Dodge Ram w/Hemi
2012 Jayco White Hawk 27DSRL
Bob, Joann and our Chihuahua Natty
kpmacaz
Mesa,AZ,USA
Posted: 04/07/12 08:45am Link  |  Print  |  Notify Moderator
Do you have a DC voltmeter with probes? Unplug everything including the rcvr and then plug only the rcvr into 120 VAC and measure the DC voltage from the center to shield (ground) of the connection on the back of the rcvr to the dish not the TV and see if the rcvr is putting out the DC voltage the LNB's need. By unplugging from the AC at first trying a shot in the dark that it may reset a protection circuit. If no DC bad rcvr!
If you do have DC voltage then do it again connecting the coax and making the same DC voltage measurement at the end of the coax to the dish (LNB's) not connected to anything at this end for this measurement. If no voltage at the end of the coax but had good DC voltage at the rcvr then replace coax.
Also when using a inline meter make sure in and out connections are going the correct way.
Let me know and i am sorry if you went through this before but it does help sometimes to just go back to basics and run through it one more time.
2007 Jayco 25RKS and 2006 GMC Yukon
2oldman
Winchester WA
Posted: 04/07/12 09:00am Link  |  Print  |  Notify Moderator
Power? Sort of unusual for folks to be measuring power, usually they're measuring whether there's any signal with an 'inline meter.'
Is is aimed properly?
schneid
In the Wind
Posted: 04/07/12 09:06am Link  |  Print  |  Notify Moderator
What dish is it?
What LNB?
What receiver are you using?
What 2oldman said, Volts or Signal?
skipnchar
Topeka or somewhere else
Posted: 04/07/12 09:30am Link  |  Print  |  Notify Moderator
ON my receiver it is difficult to read the labels for the ports. Just double check to be sure the port to the dish is the correct one. I've spent some time thinking I remembered which one was "to dish" but memory failed me
happytrader59
league city Tx
Posted: 04/07/12 09:35am Link  |  Print  |  Notify Moderator
Who makes the dish ? Some are powered by the receiver ( KVH) and some have a seperate power source.
2008 Monaco Camelot 43', 2007 Jeep Wrangler
notawordok
Polkville, NC
Posted: 04/07/12 02:17pm Link  |  Print  |  Notify Moderator
Check the wires on the back of the receiver I have went to help my friends trouble shoot thier systems and found this to be the reson they coul;d not get signal.
2000 Ford F250 XLT Latiat Superduty Ext-cab longbed 4X4 7.3 POWER STROKE DIESEL
31' travel trailer
Happy Trails
NOTA
JoannBob
Posted: 04/07/12 05:45pm Link  |  Print  |  Notify Moderator
Got it working. Whoo hoooooo. Just took me, a woman, to play with it to get it working. Only problem now is that the rv cable/satellite connection doesn't work for the satellite. Had to run the cable thru the door. We have a new Jayco and don't know why the rv wiring won't work. It does for the antenna.
h2guy
Ain't seen a sign yet!
Posted: 04/07/12 05:54pm Link  |  Print  |  Notify Moderator
You can't run a sat input cable thru a cable TV connection.
Theres 13v/18v in the sat cable that can't pass through a cable tv input connection, usually because of splitters in the cable tv line.
Over time, I'm sure you can figure out a cleaner way to route the sat cable into the RV. Just use some imagination.
Rick & Carolyn
01 Ford SC 4x4 DRW
01 CarriLite 5ver
kpmacaz
Mesa,AZ,USA
Posted: 04/07/12 07:13pm Link  |  Print  |  Notify Moderator
Great!
