RV.Net Open Roads Forum: Dinghy Towing: Cleaned up tow bar setup
Search only in Dinghy Towing
 > Cleaned up tow bar setup
offthewall
New Jersey
Posted: 05/11/12 03:59pm Link  |  Print  |  Notify Moderator
My new Jeep is 2" higher than the old one necessitating the use of a 2" riser.
I didn't like the slop and excess length that added.
I replaced the stinger on the tow bar with Blue Ox's "short" one to decrease the length.
I then added two Blue Ox Hitch Immobilizers to the setup to eliminate the "slop".
Connection is SOLID now and the overall length of the tow bar is only about 2" longer than before with the standard length stinger plugged directly into the MH's receiver.
2010 Itasca Meridian V Class 34Y
NJ tag: "THE RV"
2012 Jeep Wrangler Rubicon Unlimited Toad
NJ tag: "BLKJEEP"
Corkey05
Washington State
Posted: 05/11/12 04:19pm Link  |  Print  |  Notify Moderator
Like ...
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
charles
Ohio
Posted: 05/11/12 05:29pm Link  |  Print  |  Notify Moderator
I use one immobilizer for the drop receiver but for the tow bar I slide in a piece of 1/16" x 1-1/2" wide aluminum strip to fill the gap and hold it in place with a plastic zip lock, it works just as good as the immobilizer and you don't have to take it off. You could use steel instead of aluminum but it will rust.
