APT
SE Michigan
parkersdad wrote: If your going to trade get a Dodge Ram. But you are better off keeping what you have.
Ram 1500 has lower payload than Tundra, for the same equipment. Not a wise choice.
Anyway, why not weigh your combo? You are happy with how the Tundra performs, so I see little to gain.
2012 VW Passat TDI
PamfromVA
Fauquier County, VA
We tow our camper with a 2007 Tundra. Went to Yellowstone in the fall and just got back from Flordia. Truck has always done great. My husband and I are having the "do we move up to a fifth wheel" when we retire for longer trips discussion but I am on the side of keeping our current trailer so we can keep the truck. It is five years old, looks new, has 60K miles, and is paid for. I am planning on another 5 years of towing life from this one.
2011 Open Range Roamer 266RLS
2007 Toyota Tundra double cab 5.7-liter V8
One DH
two very spoiled camping dogs
109rfan
ny
Honestly your trading apples to apples of your towing fine your towing fine. Besides itd be financially irresponsible. Theres noway a ford would have resale your tundra does and youl take a hige initial hit on trade I'm towing a 7k trailer dry with also 1k on the tongue granted I've only brought the trailer home but I feel totally safe with the tundra I am although watching how we load up the camper keeping it much more simple
ScottG
Bothell Wa.
If your going to spend that kind of money, why not just buy a HD 3/4 or 1T P/U?
The cost will be similar especially if your willing to forgo some of the blingy junk.
Scott, Grace and Wesly
H0NDA eu2000i
W.E.BGood
Quad Cities USA
Worried about your Tundra's payload, check-out this thread on Outbackers.com, particularly "BamaOutbackers" post and picture on page two HERE
netomh
Far North Dallas
Keep it. My Tundra did NOT like 9000#, with 1150# TW. You, however, should be fine.
2010 Ram 2500HD Crew ST, 6.7L, 68RFE, bone stock.
2010 Keystone Sprinter 311BHS
1jeep
acushnet ma.
OP....i used to own a 07 tundra and can say it had no problems pulling or stopping my trailer. I moved up to gain some cargo capacity, if that is your plan than skip right over all 1/2tons and get a 3/4 gasser.
2011 F250 CC LB, 6.7 urine injection
2007 keystone Outback Sydney 32BHDS
2009 HD Ultra CVO
2013 CanAm Outlander 1000
1963 Wife..no mods
BenK
SF BayArea
First, you are comparing apples to oranges...
The Toyota is a around a 7.6K GVWR truck, while the fake half ton 150HD is a 8.1K GVWR truck
Then understand that their MTWR is NOT an absolute...it depends on their
actual weights (both the TV and trailer)
Meaning that 10K MTWR is NOT absolute...meaning that if you load either
truck till their tires blow up (pop), the MTWR is NOT 10K lbs, but ZERO
-Ben Picture of my rig
goducks10
Keizer OR
BenK wrote: First, you are comparing apples to oranges...
All the Tundras on the Toyota sites are around 7-7100 GVW. Only big payload I could find was a reg cab long bed @2000+lbs. The rest were 15-1600lbs. Funny thing is even when you do a truck comparison on there you can pick the reg cab long bed 5.7 with 2000lb payload. But when you try and build one it won't let you pick the reg cab with 8' bed.
parkersdad
North Carolina
You guys put to much into payload. If you have a half ton truck you should be staying under 7,000 pounds of trailer weight period, I don't care what the manufacturers say. If you have any question or are worried at all than you need a 3/4 ton truck. Switching brands is not going to make the difference. By the way Dodge gave up some payload to make a truck that rides better and man I sure like mine.
