PaRambler
Camp Hill,Pa
I always seem to have this problem when I fill my fresh water holding tank which I don't do often. Way before it's full water backs out of my fill hole like the tanks full. I have a 50 gal. tank and within a couple of minutes of filling with the hose, out it spews. I have a Cedar Creek 37RDQS for what it's worth. I checked the manual and it says remove the fill cap and vent plug and fill. I can't find anything that looks like a vent plug. Can anyone help?
Lann and Liz
Sadie (yellow lab)
05' Cedar Creek 37RDQS
06'Ford F350 Crew,Lariat,SRW,LB,6.0PSD,3.73
trucker495
Linden, CA
You may have a plugged vent line on the tank
04 HR ALUMASCAPE 31' TRAVEL TRAILER
05 RAM 3500 4X4 CTD SRW CREW CAB LONGBED
bpounds
Whittier CA
PA Ramblers wrote: I always seem to have this problem when I fill my fresh water holding tank which I don't do often. Way before it's full water backs out of my fill hole like the tanks full. I have a 50 gal. tank and within a couple of minutes of filling with the hose, out it spews. I have a Cedar Creek 37RDQS for what it's worth. I checked the manual and it says remove the fill cap and vent plug and fill. I can't find anything that looks like a vent plug. Can anyone help?
Had a similar problem with a trailer, and it was because the hose that runs from the fill port to the top of the tank had a low spot in it. When that low spot gets filled with water, it wants to spit back at you.
I solved it by cutting a piece of a white hose about 3' long, attached that to my fill hose, and inserted that down the hole so that the end was past the low spot. Solved that issue and the tank filled faster too.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
sch911
Rochester Hills, MI
The vent is usually in the same area as the fill. In this pic it's in the 5 o'clock position.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
PaRambler
Camp Hill,Pa
Thanks pounds. I keep a piece of hose that I cut the fitting off the fill end and tried running it way down in but it was hanging up and I didn't want to punture the fill line but I might try again. I keep going out to the camper and each time I get a little more water in it so that might be the problem
bpounds
Whittier CA
I don't know what your manual is saying about a vent plug. I've never seen a vent port that had a plug.
Now I use one of these, and it does a pretty good job of preventing spit back.
You can find it here: Coil-N-Wrap
PaRambler
Camp Hill,Pa
911, I have exactly what you have pictured as far as the vent but there is nothing attached to it from the inside which tells me I have no vent.
PaRambler
Camp Hill,Pa
I'll check out that site pounds. Thanks
MC9
Cheboygan,MI
Take a piece of hose and fit it tight to the vent and blow in it to clear the vent tube.
HappyKayakers
Black River Falls WI
I also rarely fill my FW tank that full. On the few times I've done it, water has spit back out through the vent hole. The last couple of times I kept the hose in and running just for spite. The water quit coming out of the vent in less than a minute, then a big rush of air, and I was able to finish filling.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
