RV.Net Open Roads Forum: Ford 6.0 PSD - broke down - fuel issue?
Search only in Tow Vehicles
 > Ford 6.0 PSD - broke down - fuel issue?
Page of 13
VintageRacer
Dundas, Ontario
Posted: 05/25/12 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
So here I am with my new-to-me 2005 F250, 6 litre PSD, and broke down in Montmagny Quebec. It slowly lost power over around a half hour or so, started to run very rough, and now will barely run at all. I did run it fairly low on fuel, and I could well have gotten bad fuel on my trip. If I change the fuel filters, am I likely to cure this? What can I do to troubleshoot?
Thanks, Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
NewsW
US
Posted: 05/25/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Mileage?
Codes?
CEL on?
Did you run it to point where it sputtered and died?
What makes you think you got bad fuel?
Are you running a tuner? Mods?
Maintenance?
Turtle n Peeps
California
Posted: 05/25/12 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Brian
Any CEL's Brian?
First thing you need to do is pull the codes. Never a bad idea to pull the fuel filter and take a look or drain a bit and see what you see.
Any weird smoke out the exhaust? Any idea when the EGR valve was last pulled or looked at? Also do you have a boost gauge? If so what does it read?
outside the fire"
VintageRacer
Dundas, Ontario
Posted: 05/25/12 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
OK, here goes -
50K miles
No engine check light, don't have a code scanner with me.
Yes, it sputtered and died, I drove it to a safe spot.
No tuner, no mods.
Serviced a week, and 2,000 miles ago.
I did run it down on fuel, it took 100 litres to fill, the tank capacity is apparently 115 litres, so it had around 4 gallons left.
edit: boost gauge shows that it is not making much boost at all, but then it barely runs now.
No real expectation that I got bad fuel, but I've run a bunch of fuel through it in the past week, around 8 to 10 tanks.
Thanks, Brian
mobilefleet
on the road
Posted: 05/25/12 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
6.0 are world famous for blown turbos which probably explains the low boost, and if you're getting low to no power you can just about bank on it. Look for any signs of oil leakage in engine bay from oil lines. I wish the best for you but doubt it is fuel related. Check the EGR tube as well, and all clamps from intake and exhaust hoses, they could have come loose. keep us posted
Turtle n Peeps
California
Posted: 05/25/12 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Sticky vains in the turbo would cause the low boost and that would explain the low power but not the rough running.
I would suggest you pull the filters and see what you can see. Also you need to pull any codes.
NewsW
US
Posted: 05/25/12 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
High probability it is a very simple problem.
Check for this:
Air in the fuel system.
If there is a vapor lock in the fuel system, it will also do exactly what you said.
Since you ran it low (4 gallons is still enough), that should not have happened --- unless there is an additional problem such as an improperly installed filter / filter cap.
That cause air to be sucked in, and over time --- the air will produce the exact symptom you mentioned.
Ditto for air in the oil system (another likely if you just had oil changed).
Solution --- check for air leaks first.
Then, if that checks --- do my standard fix assuming that you can still start the motor.
NewsW
US
Posted: 05/25/12 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I can't keep up with your edits.
Check for a cracked turbo hose.
The blue silicone stuff.
Or clamp blown off.
Identical symptom.
If this is the case --- you should be able to nurse it (run just at idle) and get it to where you need to go for the repair.
Turbo hoses are a stock item at most larger dealers.
MUST use the silicon reinforced hoses speced for or better.
Not your garden variety rubber hose.
If you are replacing hoses, note there is an updated clamp that does a much better job -- for more $$$
I once repaired a blown off clamp with 2 garden hose type dryer clamps as a emergency repair.
NewsW
US
Posted: 05/25/12 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.dieselpowermag.com/tech/0907d........l_ford_power_stroke_engine/photo_13.html
Cracked turbo hose.
shotputguy
Cocoa Beach,FL US
Posted: 05/25/12 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like what happened to my 7.3(2000) Had to replace the computer that is located through the passenger side wheel well(forgot the name.) someone will know the name, you can buy rebuilt ones for 1/3 the price of a new one.
Don't know how to do signature
Page of 13
