RV.Net Open Roads Forum: Truck Campers: Shakedown of the 'Armored Bear'
 > Shakedown of the 'Armored Bear'
kerry4951
East Central Pennsylvania
Posted: 06/10/12 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
seraphim wrote:
NIT PICKING FROM THE SHAKEDOWN
The 2902, pushed completely forward in a long bed: the black water valve can only be pulled out an inch before the handle hits the truck wall (the inside where the tailgate would be). It works, but would it clog with a load of TP hitting the slide valve?
Most of your issues are and easy fixes.
The black water discharge is a bigger problem. Your solids and paper will more than likely not pass thru properly. In order to get proper discharge, I would think that the valve definitely has to be fully opened, and even at that sometimes there can be issues. That sounds like a very bad factory design flaw.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
seraphim
Ohio
Posted: 06/10/12 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
An inch or two back and it won't be a problem. A two by board between the front of the bed and the camper. But you're right - it should never have been a problem.
2012 GMC 3500HD Crew Cab LB 4x4 DRW with Duramax 6.6 diesel
2013 Palomino Maverick 2902. "Panserbjorn
"I am an armored bear..."
sirdrakejr
Las Vegas, Nevada
Posted: 06/10/12 11:10pm Link  |  Quote  |  Print  |  Notify Moderator
Quote: "Door on microwave needs to be pushed firmly to close. Not a problem, except we have to replace the glass plate which came out during our travels and broke on the floor."
Same thing happened on my 1000SLLB ( same floor plan ) and hit the stove knob breaking the knob. The dish was okay but I had to buy a replacement knob. My fault for not pushing the Micro door shut.
I also found that the fridge door needs to have the second "click" to be sure it gets cold. Just shutting the door is not enough.
Travel safely and return home happy.
Frank
seraphim
Ohio
Posted: 06/11/12 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Frank - for the tip and well wishes.
We're having fun getting organized, and deciding what we're going to add/change. Everything seems to be going well.
We really liked the 1000 model like yours. It was a tough choice.
ab257
PA
Posted: 06/11/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Upgrading our shocks and Torq Stableloads did more to stop the bouncing than airbags did. But with those short slab concrete roads in that area of the country, not much can help. I thought the western part of 94 in Minnesota was going to bounce us off the road last summer - even doing only 40.
Northeast PA
Ford F350 (2008 XLT CC LWB 6.4L Diesel 4x4 ESOF 3.73 DRW 17"A/S)
Host Yukon, Single Slideout, Tent Option, Solar, 2-way Fridge, AGM.
sirdrakejr
Las Vegas, Nevada
Posted: 06/11/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
seraphim,
Look up my mods to see what I did to mine. Some make the unit a little more comfy for me and useful too. They are not expensive and easily done.
Frank
http://www.rv.net/forum/index.cfm/fuseac......../tid/25529082/srt/pa/pging/1/page/32.cfm
and here for others:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25529082.cfm
* This post was edited 06/11/12 08:29pm by sirdrakejr *
seraphim
Ohio
Posted: 06/12/12 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks ab257. I'll look into them. It rather felt like we were on a pogo stick.
The list of minor modifications is becoming extensive lol.
A set of steps is one of the first needs. We've been using picnic tables to get in and out. A set of glow steps was included in the purchase, but I haven't a drill along to do the install on the road. Want to design a set that goes down to the side of the unit, rather than straight back, and will double as a rack for the recumbent bikes.
MAV 8801
MONT CLARE PA
Posted: 06/13/12 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Looks great... enjoy camping with it.. I am very happy with my Maverick too.. I look forward to moving up to a 2902.
2011 Palomino Maverick 8801, 2005 Chevy 2500HD Crew Duramax/Allison, Timbrens, Bilsteins, Michelin LTX M/S2, Hypertech programer & Honda Eu2000
sirdrakejr
Las Vegas, Nevada
Posted: 06/13/12 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have not figured out why they are making the 2902 model. When I look at the floor plans and the weights, there is no difference between that and the 1000SLLB model. Maybe someone knows why they are doing that. It is like the old days when GM made all their cars the same and added chrome to mark them up.
Frank
kerry4951
Posted: 06/13/12 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Frank
For one thing, there's a big difference in tank capacities (fresh, gray, and black). If I ever bought a Palomino, it would have to be the 2902 just for that reason alone.
