RV.Net Open Roads Forum: Tow Vehicles: 7.3 vs 6.0
Search only in Tow Vehicles
 > 7.3 vs 6.0
Page of 13
FishOnOne
Katy
Posted: 07/01/12 11:54am Link  |  Quote  |  Print  |  Notify Moderator
I'll take a 6.0 psd with the 5speed Torque Shift tranny over a 7.3 psd any day. Not saying the 7.3 is bad but the 6.0 power and 5speed tranny makes for a better overall driving experience.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/01/12 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I agree the 6.0 with 5spd auto is far better for power and economy than than the 7.3 with 4spd auto. I bet they're both a lot closer if comparing manual transmissions, 5spd ZF 7.3 to 6spd ZF 6.0.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
NewsW
US
Posted: 07/01/12 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Smaller displacement, better fuel economy.
Less friction, heat loss, etc.
If you want a EPA 2004 truck, the 7.3 is just not certifiable including for a retrofit.
Airstreamer67
Pineville, LA USA
Posted: 07/01/12 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
"If you want a EPA 2004 truck, the 7.3 is just not certifiable including for a retrofit."
No surprise. They quit offering 7.3s early in the 2003 model year.
ib516
Up here!
Posted: 07/01/12 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
I fully agree about leaving the 6.0 at stock output, no tuning. I'm sure tuners are responsible for at least some of the failures.
Logic would dictate the same percentage of users tuned their trucks in the other two camps - so I don't see that theory holding water as an explanation for the inordinate number of issues.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
ib516
Up here!
Posted: 07/01/12 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
45Ricochet wrote:
Ford didn't have a dyno durring development that could handle the 6.0 output
OMG that explains it.
Good post Donkey
So a multi-billion dollar corporation didn't spend a few thousand to get a proper dyno to test their diesel engine before releasing it? That's the explanation for the poor reliability of the 6.0L PSD?
Turtle n Peeps
California
Posted: 07/01/12 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Good post Donkey
That's it!!! Ford did not have a dyno so they guessed on how much power the 6.0 put out. Some put out 235 and some put out 500 HP. The ones that put out 235 lasted and the ones that put out 500 didn't.
I will say it again. LOL, where do people come up with this stuff? His next post needs to start with "once apon a time." LMAO
Why thank you very much Shrek!
outside the fire"
NewsW
US
Posted: 07/01/12 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
EPA regs allowed it to be sold up to Dec 2003, so the 7.3 was used until the 6.0 was ready in the van.
Just as the 6.0 continued to be offered until 2010, in the E series.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/01/12 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, logic wouldn't dictate what you're alluding to. Logic would dictate more tuners with failures than without. I don't know how it truly sussed out in real life though, could be equal, or not. I don't think anybody truly has any real numbers to back up either train of thought, just a bunch of guessing really.
BigToe
Posted: 07/01/12 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, reading this thread is like the stories of several different blind men describing an elephant by touch, where each man only had access to one body part. Naturally, the tail, ear, leg, and belly all feel, and are thus described, very differently. And to top it off, much of what is opined here seems to be conjecture. Kind of inspires me to add some of my own hogwash to the slop:
I was hanging around inside of the International Truck and Engine plant in Indianapolis one fine summer day back in 2001, observing the installation of some fancy state of the art automated machining equipment destined to produce parts for the 6.0L motor more than two (2) years PRIOR to it's ill fated introduced to the Ford Superduty. I was hanging out with a trusted 3 decade veteran with the company who was about to retire at that time. He revealed to me that they were having trouble with the EGR in testing the Ford versions of the VT-365 prototypes they were test muling at the time. In 2001.
Navistar was having other issues as well. In fact, the 4.5L baby powerstroke was supposed to be introduced prior to the 6.0L, as early as 2002, coming out of the Huntsville Alabama plant. That didn't happen. The 6.0L was delayed because there were issues that were not getting resolved. Lots of programming issues too, with the Sturman technology (later licensed to Siemens) in the injectors.
That's why the 7.3L got extended deeper into 2003. This wasn't the original plan though. Ford did not say, oh, the EPA will let us sell 7.3's until such and such a date, so let's plan to do that. Instead, Ford wanted to be early and proactive in beating any and every EPA mandate, and use their proactiveness as a feel good marketing feather in the cap. That wasn't to be.
The Huntsville plant later got shifted to produce 6.0s whereas it was originally going to produce 4.5s. The Eddie Sturman digital technology that originally enabled not just split shots, but up to 17 shots of fuel per power stroke... and that was promised to later produce camless digital valves... eventually got scrapped. All kinds of things were going on here.
As for computers... Ford put their own computer in the 7.3L also. The T444e uses entirely different programming and protocols. Heck, even the pcm box chips, board, and location are entirely different. Again, from this particular blind mans view while walking through the hallways and down the production lines of the US plant that designed and produced 7.3L at that time, there were some folks at IH that did not like the hoops and parameters that Ford, then their largest customer, imposed.
It was kind of surreal to witness, even if just for a day or two... because this was a time period when the externally perceived relationship between Ford and IH was at it's strongest and most mutually profitable. And yet it was during that peak time that unseen seeds of discord and disagreement were being sown that ultimately led to the dissolution of this relationship entirely.
There was a lot of faith put into some fancy, fantasy technology that didn't pan out. Particularly with the injection contol system. And the EGR implementation issues surfaced early, and never went away. It's really a sad story, because had it all worked out, it would have been an awesome implementation of American ingenuity, from the Apollo space program to the heartland.
Anyway, between those two engines, for longevity, reliability, lower maintenance costs, and resale value, I'd go with the 7.3L.
Page of 13
 > 7.3 vs 6.0
