barnrt
New Jersey
Thought I would use the expertise of this forum before searching further:
My automatic awning works off a remote. It opened fine, but in closing the awning it stopped halfway. I could close it the whole way by pushing up on the bar while I held the remote button down. Just replaced the battery in the remote so I don't believe that the problem. There is also the manual button and that did not work any differently. any help out there?
wayneandylarson
Minnesota
Awnings are fun. Two shot in the dark suggestions as I am not familiar with your model, type etc.
First, my automatic awning is sensitive to low battery power. Check batteries.
Second, if you system is tied into the weather station with automatic retract try turning off the weather system and/or do a reset of the set with the remote. On my system the reset requires pushing the bottom two remote buttons for 10 seconds to reset. Good luck.
2008 Winnebago Adventurer Limited
Workhorse with Chevy 8.1 rear engine
DW aka Sarge
Pet-free zone
Voy electric scooter "Scoot"
sailor_lou
Connecticut
I'd also check and lubricate all the moving joints with a silicon spray or light oil. Good luck.
Lou
05 Travel Supreme Envoy
bluwtr49
Green Valley, AZ
What make of awning???
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
JC2
Mo
sailor_lou wrote: I'd also check and lubricate all the moving joints with a silicon spray or light oil. Good luck.
Lou
X2.
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
BigSkyBob
Helena, Montana
I experienced the same problem with my awning and found the 12VDC plug that connects the awning to the coach was the culprit. I cleaned the 4 sockets with a paper clip and the 4 prongs with emery cloth and this cured the problem. I have to do this about once a year when the awning is slow to retract. This could possibly be a solution for you but I don't know how your awning is configured.
2008 Monaco Camelot 40PDQ, 4 slides, 2012 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
imgoin4it
Alamogordo, NM USA
If all else fails it only costs about $1000 to replace the motor, and wind sensor and operator. ( Ask me how I know.)
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
trickyvic3
Raymond NH.
Good advice here, as mine does the same thing.
Never even gave any thought to lubing it for starters lol.
JimGo
Glendale, AZ
Also, if you have awning light strip inserted in the groove and leave it there when retracting, this too can make it slow. Even making an older motor burn up.
Jim and Terri
2007 Pace Arrow 37C
W22 Chassis, 8.1 Vortec, Banks PowerPack, Allison 1000
2012 Chevy Nox LTZ AWD
Black Lab "Jessi"
Bea PA
Waynesboro, PA, USA
If it is a Weather Pro it is a known problem,motor cuts off , after 2 boxes and sensors, we wired ours direct. Problem solved.
Bea PA
2004 Winnebago Journey
2008 Saturn Vue
1998 Venture Van
Brake Buddy/Remco Pump
2003 Gold Wing 1800 recently triked (Big Red)
