RV.Net Open Roads Forum: General RVing Issues: Adapter question
 > Adapter question
WHS
Waitsburg, Wa.
Posted: 08/04/12 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I have a standard 30amp unit that came with the standard black adapter for the Power cord. I recently bought a Honda 2000i generator to run my AC. I had noticed previously, that the Stock black adapter had gotten pretty hot when so when I ordered a hard start kit I also bought a new yellow Camco 15 to 30 adapter. Then I read this on another thread "Get a dogbone type 15/20amp to 30amp RV connection adapter though. Forget about the little black plastic adapters".
My question is why? I don't mind spending Another $25 or so, but is it necessary to get the dog bone style and is my bigger yellow adapter ok?
Thanks,
Skip
05' Layton Lite 170LT Cascade edition
06' Chevy Silverado K1500
We-No-Nah Rendevous, a Ljutic, a Remington, a Hard Rock Pro, a Polaris 550XP & Raleigh the Hunter
dupreet
High Point, NC
Posted: 08/04/12 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Connections in an electrical circuit inherently create heat. In the case of a "puck", there are two connections right next to each other. With a doggone, the two connections are spread out. The dogbones also use standard connectors that I feel are made better.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
PenMan
New Mexico
Posted: 08/04/12 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I use the standard puck adapter that came with my trailer. It does not get hot, maybe a little warm is all.
Chris and Jane and two boys (and a DDIL) who prefer tents
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
jamstoyz
Chesterfield MI
Posted: 08/04/12 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
I dont know how may amps your ac draws but sounds like your gen isnt big enough to run the air and anything else thats on it your unit. 2000watts is 16 amps
2001 Gulfstream Yellowstone 29'
1999 Fleetwood Prowler TT 24' (sold)
2004 Fleetwood Gearbox Toyhauler 28' (sold)
Ron3rd
Upland, CA USA
Posted: 08/04/12 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Either adapter will work. I used to use the small one like the Camco then switched over to the dogbone style because it was more convenient IMO.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Sillybugs2
Washington
Posted: 08/04/12 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
We have this one that we use to hook up our trailer to home power. http://www.amazon.com/Camco-55165-PowerGrip-Dogbone-Electrical/dp/B000BUU5YA/ref=sr_1_4?ie=UTF8&qid=1344111198&sr=8-4&keywords=camco+adapter
We plan to use it as well with the new Honda 2000 we just purchased today. Although we know it won't power our a/c. We rarely need it anyway and if end up needing it more when we don't have hookups we will get a companion.
Carolyn
2010 Dutchmen Sport 27B
2001 F150 Supercab 4x4
Wherever I happen to park
Posted: 08/04/12 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
There are two reasons the dogbone is better and there is a better adapter as well in your case.
The first is that it puts less strain on the smaller outlet
The second is that with a foot of wire between it's male and female ends the heat dissapation is way way better, That little black puck adapter concentrates the heat from BOTH plugs in a small area.
The better one is a larger block that covers both 20 amp outlets and has a single 30 on it. I had one, Lost it. More contact area (2x on the 20 amp side) means less resistance means less current through each pin, means less heat.
Gale Hawkins
Murray, KY
Posted: 08/04/12 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
WHS I love this option because lower power loss but not sure if still made.
JJnLilly
Ohio
Posted: 08/05/12 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Looked for it Gale, but can't find it currently being offered.
2007 Ram 2500 QC CTD
2010 Wildcat 28RKBS
tomman58
Southeast Michigan
Posted: 08/05/12 07:18am Link  |  Quote  |  Print  |  Notify Moderator
There is no difference electrically between the two connections. Current is current and the fact one is long than the other is really not a big deal
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
 > Adapter question
