johncrazyels
Vancouver/California
We plan to store our 5er indoors this winter (our first cold winter since 1993!!) We will not have access to any power - should the batteries be removed so they can be trickled charged at home? If they are removed, anything else we should consider? Thanks.
pianotuna
Regina, SK, Canada
Hi,
Fully charge them, and remove any parasitic loads. The colder it is the less self discharge that happens.
edited 10/10/10 07:14am by pianotuna *
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Dr Quick
M'boro, Tn
A battery will sulfate if left uncharged for much over a month. This will permanently damage the plates in the battery and keep it from accepting a full change in the future. The trickle charger will stop this from happening and extend the life of the battery.
Dr Quick
Vulcaneer
Northern New England
Remove them. Trickle charge couple of days per month and check their fluid levels.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto, Ultimate Lariat pkg
2011 Open Range 393RLS 14,250 GVWR
Pullrite Super Glide 18K
garysol
Avon Ohio
I remove my battery and check the water and add some distilled water as needed. I then put the battery in my basement on a piece of wood to keep it up off of the concrete floor and I then attach a small Battery Tender to the battery and forget about it until spring....
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
Sean32
Brampton Ontario Canada
garysol wrote: I then put the battery in my basement on a piece of wood to keep it up off of the concrete floor ...
That's not required, to keep them off concrete. There is no proof that having a battery on concrete will harm them in any manner.
I do agree with trickle charging them with an automatic charger and to removing it. I do it on the trailer and my boat and have done it every year.
2009 F150 4x4 Platinum with Max Tow, Pullrite 12K slider with pins, 2010 Keystone Cougar 27SAB with aluminum rims, remote, and Polar
garysol
Avon Ohio
Sean32 wrote: garysol wrote: I then put the battery in my basement on a piece of wood to keep it up off of the concrete floor ...
That's not required, to keep them off concrete. There is no proof that having a battery on concrete will harm them in any manner. .
Sure can't hurt.
Mile High
Denver, CO
I personnally don't dedicate any time "babysitting" my batteries. I pull then cables, leave them in the trays, and lock the door for the 6 months of winter. If they survive, they survive - if not they get replaced.
4-years and going strong on the 6-volt. The boat 12-volt battery automatically fails every 5 years, so I expect the same from these 6-volts.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
pianotuna
Regina, SK, Canada
Hi,
Having a battery on concrete won't discharge it--but if there is any spilling--a whole floor is much harder to replace than a piece of wood or other protection.
Pipeman
Windsor, Ontario, Canada
I take my 2 out and store them in the basement, ON WOOD, and put a smart charger on them at least once a month.I do have a volt meter also hooked up to see where the voltage is.Storing on concrete will not harm the batteries according to a web site that I went to.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
