RV.Net Open Roads Forum: Afraid I will drag off dump valves on Kiwi 21C
Open Roads Forum  >  Hybrid Travel Trailers
 > Afraid I will drag off dump valves on Kiwi 21C
orggardn
columbia, tn
Posted: 10/14/05 06:24am Link  |  Print  |  Notify Moderator
With my trailer setting level in the driveway, the dump valve is barely 5-6 inches off the ground. Since this is my first "trailer", I'm not sure how much that clearance will vary as I tow and back into campsites. It just looks like it is an accident waiting to happen.
I've contacted Dexter and they do not have a lift kit for the axle that is on my unit. I am concerned that a small ditch or even a good sized speed bump will cause me to drag the PVC dump valve and drain pipe. I've looked under the trailer and the frame prevents me from raising the drain system any.
Anyone else have this issue? Anyone have an idea on how to resolve?
Me,"The" Woman, 3 young'uns, & the dawg
2003 Astro
2002 Jayco Kiwi 21C
(moved on from a 1996 Coleman Sun Valley)
grizzlygiant
Coeur d'Alene, North Idaho, USA
Posted: 10/14/05 06:34am Link  |  Print  |  Notify Moderator
Bad design and, Yes, you will knock it off sooner or later. I had such an arrangement on a previous motorhome; dumped a tank-full of #### down the driveway once and another time on I-5 on a hot summer day. The latter was just a stream which distributed the contents for several miles, both on the road way and on following traffic. The fix -- I could never find one. Sorry
North Idaho
2008 Heartland Big Horn 3400RL fifth wheel
2007 Dodge Ram 2500 4x4 5.9 Cummins
kenhall64
Magnolia, Delaware
Posted: 10/14/05 06:38am Link  |  Print  |  Notify Moderator
How close is dump valves to tires. Most of time they are so close that tires protect from damage.
2006 Fleetwood Pegasus 190XP
2003 Chevrolet Tahoe LT
2004 Toyota Sienna
Wife and 6 year old son
Trek 5000 OCL Road Bike
Trek Mountain Bike
http://community.webshots.com/user/kenhall64
weas3kids
Shenandoah Valley - Virginia
Posted: 10/14/05 06:42am Link  |  Print  |  Notify Moderator
We have a Jayco with a drain that is pretty low too. We have a long driveway (live in the woods). It is very uneven (grass in the middle still), and we have a good sized "ditch" at one point that allows water to cross when it rains heavily. We thought for sure it would drag. It didn't, and I think it is because it is near the tires.
Me, DH, DD(7), DS(5) & DS(3)
2008 Jayco Eagle SuperLite 31.5 FBHS
2003 Ford F250 7.3L PSD
Sandlakejake
Hayward,WI
Posted: 10/14/05 06:48am Link  |  Print  |  Notify Moderator
I have the same design and it worried me, but after many miles and dragging the rear bumper pads on many occasions the dump valve is still untouched.
1999 Ford F250 Lariat ext cab (for 12 year old Lab) V10 auto 373 W/Prodigy brake control
2003 Jayco Kiwi Too 28R
skipnchar
Topeka Kansas USA
Posted: 10/14/05 06:52am Link  |  Print  |  Notify Moderator
Are you sure there aren't some "V" shaped drag bars on the back of your trailer? Usually when there is low ground clearance these are pretty standard on most brands. They are designed to drag the ground in circumstances where the plumbing may be damaged. They don't offer complete protection but they do work pretty good when folks don't try to "improve" them with wheels. If you find you have them, run a string from the bottom of the rear tire to the bottom of the drag bar. Your plumbing SHOULD be higher than this string, indicating you will benefit from their protection.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
tomhole
Loveland, OH
Posted: 10/14/05 07:20am Link  |  Print  |  Notify Moderator
Can you add some of those anti-scrape triangle things to the rear frame? My 23ss has one on the I beams on each side about 2 ft in from the back of the trailer. I was going to get some of those metal wheel thingies to put on them so they rolled instead of scraped.
Wife, 2 girls 13 & 11, 2 mini schnauzers, 2 cats, a pig and a fish
2008 Toyota Tundra 4x4, DC, SR5, 5.7L, 6 spd, 4.30 rear
2005 Toyota Sienna XLE
2008 Rockwood 2701SS
F/A-18 Hornet 0-175 mph in 2 seconds
mwebber78
Maine
Posted: 10/14/05 11:07am Link  |  Print  |  Notify Moderator
I noticed my JayFeather 23B has some low plumbing too, but they all do except riser equipped HTT's. It seems the plumbing is purposely located near the tires. After going to a campbround last weekend that SHOULD have rubbed the plumbing right off the trailer, I am happy to report no damage!! The pipes never got closer than 3-4" from rubbing, even backing up a grade to park the camper.
Michael
2 DD's and my DW
6 Acre's in Southern Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD LT 4X4
Camping Pictures
thatguy1967
Springfield, Missouri
Posted: 10/14/05 12:07pm Link  |  Print  |  Notify Moderator
My coyote doesn't have a riser kit and there's lots of clearance (12"+).
2002 GMC Sierra 1500 2WD Ext Cab, 5.3L, 3.42 axle
2006 KZ Coyote 23CMS, Equalizer Hitch/Voyager Brake Control
AnnaBanana
Wentzville, MO.
Posted: 10/14/05 05:06pm Link  |  Print  |  Notify Moderator
We also own a Jayco with low clearance. We have towed and camped over all types of terrain this camping season, and we have never scraped or dragged a single time.
AnnaBanana, O.R. nurse
Daughter, Melissa, recent Mizzou graduate!
Mandy, our adorable golden retriever
2005 Jayco Jayfeather 25E
2004 Dodge Durango 5.7 Hemi "the green machine"
Topsail Hill Cult Member
