RV.Net Open Roads Forum: Tech Issues: Wiring Diagram
 > Wiring Diagram
Tee
Highland, Utah
Posted: 01/22/07 03:58pm Link  |  Print  |  Notify Moderator
I am getting ready to run a couple 110v outlets, a light and a battery for my enclosed car hauler. Does anybody have a wiring diagram that I could use to help make sure I get it set up right?
Thanks in advance
Mega Cab Dually CTD 4x4
Lance 861
hershey
Albuquerque,(fulltime) NM, USA
Posted: 01/22/07 04:11pm Link  |  Print  |  Notify Moderator
Assuming that you know you will need two completely different wiring circuits for the 110 volt outlet system and the 12 volt system. Insure that you bring each of them together to their own breaker or fused panel for safety.
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
kgmz
Portland, OR and Eatonville, WA
Posted: 01/22/07 05:56pm Link  |  Print  |  Notify Moderator
A couple of questions.
How are you getting the 120 into the trailer and what is it running?
What is going to charge the 12v battery and what is it running?
We have 120 volt plugs in our trailer, a convertor/distribution panel to keep the battery charged and to power any 12 volt items when plugged in to 120. We have a marine twist lock receptacle on the front of the trailer where we plug the 120 in, either into another marine twist lock on the motorhome to be powered by the generator or into a adapter cord so it can be plugged into a normal household socket. The 120 then runs into the converter panel and then to the plugs. The 12 volt runs from the converter panel to the battery and to 12 volt lights, furnace, etc. The battery is also charged by the tow vehicle but separated from the breakaway battery by the breakaway charger, so that the breakaway battery does not get discharged by lights in the trailer, etc.
Go to this thread to see some pics of trailers with outlets, furnaces, etc. in them.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/18836124
1998 29' Itasca Sundancer pulling a 2002 Interstate West 27' All-Sport, 10,400 GVWR with Yamaha Mountain Viper's inside.
2001 Suburban 2500 LT,8.1,4.10
2001 2500HD Crewcab Longbox LT,8.1,4.10
Tee
Highland, Utah
Posted: 01/23/07 09:04am Link  |  Print  |  Notify Moderator
120 will go into the trailer thru a typical RV 30amp cord. I have already installed door in the side of the trailer and have the cord.
Charging is one of the items I am trying to figure out. I was thinking I could have it charge off the truck. But being able to charge off plug in would be great! The 12v battery would be powering a radio (to hear the track announcer and tunes) A fantastic fan, three interior and two exterior lights.
The 120 would be powering a roof AC unit, Two interior outlets and 1 exterior outlet, 1 interior flourescent light, two exterior flood lights.. I would use either the Gen in the camper, a portable gen, or household/utility feed, depending on what I am doing and where I am.
This trailer is used for my daughters Jr. Dragster. I am trying to get it more like a mobile garage than just a trailer.
Thanks for the link, that helps.....
SWMO
Southwest Missouri
Posted: 01/23/07 09:28am Link  |  Print  |  Notify Moderator
I would visit some RV salvage lots and get a converter. Run the 120V wiring using what is called MC, which is basically a metal clad cord. You could then safely use the MC to attach your 12V whenever possible. Run your 12V exposed in Red and Black. Whatever you decide, don't run any 120V unprotected or in a way that it can be confused with the 12V, it is deadly.
2009 Dodge 3500 Laramie, DRW, 4X4, auto, 6.7L, B & W Companion.
Jayco Designer 34RLQS, Mor/Ryde
kgmz
Posted: 01/23/07 09:02pm Link  |  Print  |  Notify Moderator
You should get a converter/AC panel used or new. With air conditioning, etc. you will need to separate the circuits and have curcuit breakers. Plus you will have a fuse panel for the 12 volts stuff and have a way to charge the battery.
Tee
Highland, Utah
Posted: 01/26/07 11:25am Link  |  Print  |  Notify Moderator
What do you guys think of one of these for the battery in the trailer.
Charger
sljkansas
Miami Co. Kansas
Posted: 01/27/07 08:05am Link  |  Print  |  Notify Moderator
That charger is for maintaining the battery when not in use. If you want to keep the battery up while using it, you will need a better charger, or even better a converter. SWMO gave a good suggestion but buying a used conveter from a RV salvage yard. You can get newer to old ones for a fraction of the cost of a new converter.
Hers's link to a list of RV alvage around the country RV Salvage Yards
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
Tee
Highland, Utah
Posted: 01/30/07 01:21pm Link  |  Print  |  Notify Moderator
Ok, searches and phone calls to the salvage places turned up many but they were almost the price of new.
Found this one here Converter/charger
Am I getting back on track now?
AyJay
South Eastern MA, USA
Posted: 01/30/07 02:28pm Link  |  Print  |  Notify Moderator
Hi:
If you are shopping E-Bay........ do a search for an "inverter/charger" rather than a converter/charger. I believe you'll have a larger selection.
AyJay (ARS W1GDJ)
1979 RTS Bus Conversion
DD 8V71TA, Allison V730
2007 Saturn Aura Toad
USAF Retired 1972
When I die I want to go like my Grandfather, peaceably, in his sleep.
NOT like his passengers who went screaming and yelling!
Inside Bus Pictures
 > Wiring Diagram
