RV.Net Open Roads Forum: Flat towing a classic VW Beetle (circa 78)
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Flat towing a classic VW Beetle (circa 78)
Timbear
DADE CITY, FLORIDA
Posted: 04/11/08 11:12am Link  |  Print  |  Notify Moderator
Anybody had any experience flat towing a 1978 or 1979 VW Beetle with manual transmission. I can't find any definitive information, but have seen them being towed. Since there are a number of tow bars available, I would assume it must be possible (at least for a limited distance/time). Thanks.
MAJESTYPOINTERS
MONROE, MI.
Posted: 04/11/08 11:17am Link  |  Print  |  Notify Moderator
WE USE TO FLAT PULL A DUNE BUGGY.. SIMALAR TRANS AXEL. PUT IT IN NUTRAL AND WE TOWED 400MILES EACH WAY WITH OUT PROBLEMS.
Timbear
DADE CITY, FLORIDA
Posted: 04/11/08 12:15pm Link  |  Print  |  Notify Moderator
What kind of supplemental braking system did you use? Any special considerations with the tow bar? Thanks.
Qlake
Kansas City KS. or Port Charlotte FL.
Posted: 04/12/08 07:08pm Link  |  Print  |  Notify Moderator
You can flat tow any air cooled VW beetle manual or auto-stick, just put it in neutral. There are inexpensive tow bars for a super beetle at www.veevillage.com that are very easy to install and use.
mowermech
Billings, MT
Posted: 04/11/08 01:25pm Link  |  Print  |  Notify Moderator
When I knew people who towed the classic VWs, "supplemental braking" hadn't been invented yet. There used to be a towbar available that was especially built for the VW Beetle and Superbeetle. I would imagine they are still available somewhere, perhaps in VW specialty catalogs.
I have heard that the "Automatic Stick-shift" VWs are not flat towable. I don't know if that is a fact or not. As far as I know, the Beetle, Super Beetle, Karmann Ghia, and Thing are all flat towable, and the same towbar fits them all.
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toy: 1999 Dodge QC SWB, Cummins, 5 speed, 4X4
Other toys: a pair of Kawasaki Brute Force 750 ATVs and a boat.
MAJESTYPOINTERS
MONROE, MI.
Posted: 04/11/08 01:52pm Link  |  Print  |  Notify Moderator
NO WE DID NOT USE ANY SECONDARY BRAKING SYSTEM. IT WAS A LIGHT DUNE BUGGY AND DID NOT EFFECT THE BRAKING OF THE BIG OLD WINNY WE HAD BACK THEN. THE FLOOR MOUNTED ONES THEY HAVE NOW SHOULD WORK FINE...JUST DROP THEM IN PLACE, AJUST AND YOU ARE READY TO GO (OR STOP AS IT WERE). THE TOW BAR WE HAD WAS HOME MADE "A" FRAME THAT CONECTED TO THE 4 BOLTS THAT HELD ON THE FRONT AXEL TUBES. I DONT THINK I WOULD TRUST THE BUMPERS ON THE OLD VW UNLESS YOU HAD SOME HEAVY WAY TO TIE IT BACK TO THE FRONT AXEL. IF I REMEMBER THE BRACKETS RIGHT THEY WERE ONLY FLAT STEEL TO HOLD THE BUMPER IN PLACE NOT MUCH SIDE WAY STRENGTH.
jcamp123
Putnum County, New York
Posted: 04/11/08 05:01pm Link  |  Print  |  Notify Moderator
No need for any braking system. Just wire it up, hook up the tow bar, put it in neutral and go for it. If it is a Super Beetle it takes a different tow bar than the regular beetle. The only problem is the VW is so light you will need a rear view camera to make sure it is still there.
Joe and Susan
Tara the toy poodle and Patches the cat
Retired Teamster traveling when I can
2006 Allegro 32 BA
2009 Saturn Vue Red Line
FMCA 50826
He who dies with the most toys wins !!
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
