RV.Net Open Roads Forum: Fixing water damage on the old Dodge (pics)
 > Fixing water damage on the old Dodge (pics)
Page of 67
Class C Motorhomes Related Tips
Gale Hawkins
Murray, KY
Posted: 10/05/09 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
kraazy3 wrote:
I have been a carpenter for 30 years and if those trusses were designed correctly they are supposed to transfer the weight down not out. The trusses are designed to give height clearence but the cross ties are still there to prevent separation of the walls. If I had any concern at all it would be side to side. I would be sure to cross brace the far end to prevent the wind from blowing the building over sideways. This should stand a considerable snow load with no problem. I would consider metal roofing to help shed the snow. I would trust this building in Vermont where I live.
Ron C
I am with Ron on this. It is not the downward forces I would be concerned about first. I know they are a pain but some external braces could help prevent the wind from "racking" it.
Spectramac
Monroe, WA
Posted: 10/05/09 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I agree, the roof itself is VERY strong, but you can rock it around some forward and back and without the cross bracing, left and right. I will be adding some additional braces after I get the roof finished.
Malcolm
tempforce
Pacific Wonderland
Posted: 10/06/09 06:52am Link  |  Quote  |  Print  |  Notify Moderator
a nice strong 'x' brace on the back wall, and a couple '/' or '\' braces on the sides would do the trick. make the side ones so they can be removed if necessary to move large items. should stiffen the shop up without costing another arm or leg.
Charles
From the Coast ranges of Oregon
'08' Dodge mega limo-cab, 409, kelderman rear air ride
'02' Holiday Rambler TT, the Gypsy Wagon.
'83' Ford Ranger, 2.2 Diesel (30-38 mpg).
'56' Ford F-100 project
BurbMan
Long Island, NY
Good Sam RV Club
Posted: 10/06/09 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
At this point, why don't you pick up some plywood and sheath the sides and back? That will keep those posts braced and square, keep the wind out of the place, and keep the wind from getting under the roof...You did a great job on the shed, but honestly I don't see the point without walls, a slight breeze when it's raining or snowing and whatever's under there is getting wet.
bondebond
The bluest spot in Kansas
Posted: 10/08/09 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
My thoughts, exactly. Not that it would help from a structural standpoint, but I would at least be attaching tarps to the side posts to keep blown water/snow out of the RV while under it.
Myself, The Boss, and two wanna-be Bosses
2006 Jayco 1007
Yum...nature is tasty.
kraazy3
Vermont
Posted: 10/08/09 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have a couple more suggestions. As I said I would surely x brace the end and lag bolt them as nails could work loose if the building starts to move in a high wind. I think the braces for the end to end look good as they come down almost half way but as on the end bracing I would lag bolt them as well. The part about the wind blowing the roof off. If you enclose 3 sides the wind might get in and lift the roof but if you don't enclose the sides the wind will just blow right through. I also noticed that you have used metal brackets to attach the carring beam to the top of the 4x4 posts which will help keep the roof in place. The only other issue is how well you have the posts anchored to the ground. If everthing else is hooked together the only thing that could happen is that the whole building could fly away. The structure itself looks pretty good. Just take as much wobble out of it as you can. I can't wait till you get going on the motor home again.
Ron C.
kraazy3
Vermont
Posted: 10/08/09 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
I thought I remembered something so I looked back and saw that you did indeed anchor the posts. You have done such a good job on the building I don't know why I questioned you. GOOD JOB
Ron C.
RVSKIER
Seattle, WA
Posted: 10/09/09 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Man with this group here it's like haveing thousands of backseat drivers telling you what to do!
RVSKIER
2001 Itasca 30W
Faster, Faster, Until the Thrill
of Speed Over Comes The Fear Of Death
gkainz
Arvada, CO, USA
Posted: 10/09/09 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Hey! HEY! Eyes on the road, Mister!!!!!
'83 Tioga 27' Ford E-350 460
'97 Dodge 2500 CTD 4x4 in need of a TC
CISCO8325
Peoria,az.
Posted: 10/09/09 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
are we there yet?
Page of 67
