Pigkisser
West Texas
For the time being, why not run an extension cord from a working outlet to the TV and Satellite? I know it's not the perfect setup, but at least you will have the TV in it's usual place and not on the table.
2007 Jayco Seneca 33SS
2008 Jeep Wrangler 4 door 4X4 toad
Ready Brute/Ready Brake tow bar/brake combination
Igloo Ice Chest
Liquid_Vitamins
Oak Forest, IL
That would make way too much sense.
I am a little worried about overloading another outlet but if it's just the Tv and dish that should be fine.
I could even run it from the power post and free up the outlet under the table.
THANKS!!!!!
Funny how you look at only one way of getting things done.
Steve
2008 Jayco Seneca HD 36FS
Bobbo
Memphis, TN
My inverter has a GFI built in. Did yours trip?
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
Liquid_Vitamins
Oak Forest, IL
Not sure. I have never seen it when going over the coach.
Anyone know where Jayco usually put them?
Steve
Liquid_Vitamins
Oak Forest, IL
WooHoo!!!
I found the problem (and the inverter). After reading through some posts here I figured out where the inverter should be (under the bed). It took some work but I finally found it.
Of course it's a pain to get to and they installed it right up against the back wall but after getting my fat little body in there I found a GFI right on the inverter. I reset it and everything came back on.
THANKS to everyone here for their help. I would not been able to find it without your suggestions.
Steve
LIRacer
Long Island, NY
Did you check the power strip that the TV and DVD are plugged into? My 06 35GS has a power strip that is fed from the outlet BEHIND the removable covers next to the from TV. The TV and DVD are plugged into this strip which has a breaker. Check that.
Bruce, Fran, 4 kids
2006 Jayco 35GS
