FS3000
North CA
Hello,
We are looking to sell our WW FS3000, and get into a 28-32ft 5th wheel.
1. What can I expect in terms of MPG with a 06 F250 CC PSD SWR?
2. What's a good candidate for a 5'ver that won't exceed my TV GVWR?
Or worst case we move into a 25ft for a couple years and see what is available after that.
RE_Todd
Lemoore, CA, USA
FS3000 wrote: Hello,
Or worst case we move into a 25ft for a couple years and see what is available after that. I went from 10MPG at 57 MPH to 9.5 MPG at 57 MPH with whats in my signature. Havn't towed full load yet though.
TinBenders
Formula Toy #006
2007 Can-Am 500 MAX XT
2009 Eclipse Attitude F37 AKS, it's still not white!!
08 F350, $X$, CC, dually.
lincster
Mesa Az
Sorry to say, but none of the wide body 5ers will stay under your GVWR of your truck.
Unless you look at something like the superlite series by Warrior, or something similar to that.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
dwrat
Phx, AZ
The LE 3105 or 3305 will fit your truck fine.
As for mileage, it will be the same, around 10 mpg if your lucky.
JIMNLIN
Big Cabin, OK
you can check in on thedieselstop.com for lots of input on mpgs from a all PSD owner web or input on what your truck can carry/pull.
I use axle/tire caps to load my trucks and RAWR in particular as the rear axle carries the load. I tow a 11200 GVWR 28' with two slides with my 2500 with 2200 lbs of pin weight and I'm under all weights. Keep your 5ers pin weight under approx 2500 lbs or your RAWR and you will have no problems.
Nothing wrong with using your trucks GVWR which is well under your trucks tow/haul weight numbers GM gives us to load these trucks.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
720Deere
Maryland
Pin weight is going to be the issue on an F250. For total gross trailer weight a 6.0 F250 is rated at 16,000 lbs so you should be able to legally handle a sizable unit as long as you don't exceed the rear axle rating on the truck.
As far as fuel economy, I wouldn't expect more than 10 mpg in stock trim. At the same time, I would strongly recommend that you not tow more than 6 or 7,000 lbs in anything but stock tuning on a 6.0. The little bit of money you will save in fuel will disappear fast unless you are lucky enough for Ford to cover the carnage under warranty.
2006 Ford F-350 4X4 CC LB SRW 6.0
2005 Rockwood 8283SS Fifth Wheel
B&W Companion Hitch
Twin Honda EU2000i
1 wife 2 kids and 1 dog
Bill&Barb
Beamsville,Ontario
I have that exact Tow Vehicle and tow a 2005 12000lb GVWR Mountaineer 328RLS 5th wheel. Truck engine/brakes/Tow Haul mode have no problem; I hardly even notice that it's back there. Turbo kicks in nicely on hills and interstate driving above 60mph.
Bill&Barb
Beamsville,Ontario
PS _ I track my MPG - I average 10.8 but it ranges from 9.7-12.3 depending on speed, hills, etc. I typically drive 60-65mph.
My pin weight is just under 2000lbs - right around the limit for this truck when it's loaded up with hitch, passengers etc.
08f450psd
Westminster, Maryland
Bill&Barb wrote: I have that exact Tow Vehicle and tow a 2005 12000lb GVWR Mountaineer 328RLS 5th wheel. Truck engine/brakes/Tow Haul mode have no problem; I hardly even notice that it's back there. Turbo kicks in nicely on hills and interstate driving above 60mph.
But this isn't a toy hauler is it ? Toy haulers are known to have heavier pin weights (as a percent of total) to offset the weight you will be putting behind the axles.
