RV.Net Open Roads Forum: Travel Trailers: Gray water black water
 > Gray water black water
Redrider910
Alberta
Posted: 09/30/08 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Has someone add a pump to transfer from the gray tank to the black tank???
I find my self all ways adding fresh water to the black tank before dumping. Also the gray is all ways full way before the black tank when were dry camping.
Thanks Redrider
quabillion
Fulltime Native Texan
Posted: 09/30/08 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
put the cap on the 3 inch "outlet" pipe and open both gray and black valves.
The tank levels will equalize assuming that the rig is level.
Perhaps tilt the rig towards the black tank to get more into it.
1442 watts of solar on the roof. 600AH AGM battery bank. Prosine 2kw inverter. 6KVA diesel gen with auto start. 100% off grid since 6-1-03
34f Skyline
03 F250 5.4
If you can read this thank a teacher, and since it's in English, thank a soldier.
Battery FAQ
gamingdad
Anchorage Alaska
Posted: 09/30/08 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
If this is so, don't you think there would be some "stuff" coming out that you would rather not have lying around when going to dump??? Just my thoughts...
quabillion
Posted: 09/30/08 11:19pm Link  |  Quote  |  Print  |  Notify Moderator
If you do it right, the "stuff" will be gray water. Which can be much easier to handle.
Just place a bucket or suitable catch pan under the cap when opening.
Its not that big of a deal, and the alternative is $$$
mosseater
Dillsburg, PA
Posted: 09/30/08 11:47pm Link  |  Quote  |  Print  |  Notify Moderator
I suggested this quite a while back and was soundly trounced even with the flame suit on. I mentioned it as a way to help flush out the black tank after dumping it, but I think it would work for this problem too. We tend to fill up the grey a lot faster than the black also. I suspect we will now get the crowd saying they don`t want bacteria in their grey tank. But again I ask you, what about that raw chicken, eggs, other neat stuff you washed down the drain?(flame suit, ON)
I ,too, think the grey will always flow into the black as long as the grey is fuller than the black and the tanks are mounted at the same level. You could lessen the problem of residual fluid in the y-pipe by using one of those flusher thingies with the extra valve on it. Someone help me out here, what`s the name of the it?
Sunset Creek 298 BH
quabillion
Posted: 09/30/08 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
The ???king?
That thing?
LOL
Flushking I believe is what mosseater means.
Dick_B
Palos Heights, IL USA
Posted: 10/01/08 05:04am Link  |  Quote  |  Print  |  Notify Moderator
Install a `Sewer Spill Eliminator' on the end of the discharge piping and all the gray/black stuff will be contained until you open the valve. CW has a look-alike version, I think.
Yes it costs money; about six gallons of gas.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
rockhillmanor
On the Road
Posted: 10/01/08 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I have to admit I did immediately think the same thing.
BUT, the small amount of water kept in the toilet bowl is the 'only' thing that keeps the sewer gas/bacteria from escaping into your coach.
The p-traps in the sinks would function in the same manner and actually better because it 'always' stays there preventing anything from coming back up thru the pipes.
Actuallly because there is no s-curve to hold water in an RV toilet, when we flush an RV toilet we 'open' that lever straight to the tank and it 'stays' open while we flush.....letting booey bacteria to enter the air right where we are standing.
Soooo 'technically' the sinks to gray tanks 'are' much safer.
31 ft Four Winds
Chevy Tracker 4x4 Blue Ox
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
31 tundra
Elizabethtown, pa.
Posted: 10/01/08 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I read an article about this subject and I will try to find and post a link. This person took a waterpump and hooked to the gray tank and then plumbed into the black tank vent tube. In doing this, it insured that there would never be any back flow into the gray tank because the black tank would never get to that level. When the gray got full, he simply hit a switch and transfered to the black.
here is the link
* This post was edited 10/01/08 07:46am by 31 tundra *
05 E-350 15 pass.van
08 Tundra 31 BH-DSL
H & E
North Texas
Posted: 10/01/08 06:26am Link  |  Quote  |  Print  |  Notify Moderator
We stayed at a campground that came around and pumped the tanks with a honey wagon. The guy opened both valves at the same time. The next time I dumped there was some dark water in the gray. I filled the tub and let it flush out the gray tank a couple of times and now I just get gray water from the gray tank. Based on that I would never open both valves at the same time.
