RV.Net Open Roads Forum: Fifth-Wheels: Lime-Away
 > Lime-Away
Mountain Mama
N. TX
Posted: 10/01/08 09:00am Link  |  Quote  |  Print  |  Notify Moderator
We've had some trouble draining the black tank of our previously owned RV..yesterday after letting it still full of water for about a month, DH drained it again and clumps of soft, calcium stuff came out with the water. We figure that is what has had it clogged up....Am thinking of getting some Lime-Away and putting it in black tank...I've never used this and can look when I get to Wally World later, but thought I'd ask if anyone knows if this is safe for plastic, such as black tanks??? If not, does anyone have any other suggestions. We are going to use the Geo Method, but will have to order the water softner online and have a trip this weekend.
TIA!
2003 Holiday Rambler Alumascape 34RLT
Big Katuna
Deland, FL
Posted: 10/01/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
If I buy another used RV, I am going to find an All Pro Water Flow service and have them do my tanks. I saw them in Quartzite a few years back. They have nationwide franchises. They have adapted a pressure washer with flexible hoses and special nozzles and a camera and go up through your valves and thoroughly blast your tanks clean including the sensors. About $100 or so if I remember.
CLICKY LINK
If not that then try the third full tank and a few bags of ice trick and drive down some bumpy roads and drain.
My Kharma ran over my Dogma.
arizonadesertbrat
Mt Pleasant, TX
Posted: 10/01/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
You might check WalMart again for the Calgon, I am finding it again there, however it is not by the laundry detergents. At our WM it is in a center isle display before you get to the laundry products. You might check w/an attendant in that department. Might save you from having to order on line and waiting for it to arrive.
JudoJeff
Southwick, MA
Posted: 10/01/08 09:15am Link  |  Quote  |  Print  |  Notify Moderator
To answer your question, Lime-Away will not hurt your black water tank or piping. (If it is calcium deposits from hard water, this should get rid of them.) Good luck!
K1BE Jeff
Mountain Mama
N. TX
Posted: 10/01/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, arizonadesertbrat, I'll ask this afternoon when I go back tp W. M. "one more time". And thanks, too, JudoJeff, I'll go ahead and get some Lime-Away, too!
Bumpyroad
Virginia
Posted: 10/01/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
the best investment is a black tank sprayer that mounts on the wall opposite the drain.
bumpy
tvman44
Southwest Louisiana
Posted: 10/01/08 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
I get it at WalMart.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
WayneZat
Tucson, AZ
Posted: 10/02/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Since Limeaway is sold in a plastic bottle I would not think it could harm a plastic black water tank. A better product at Walmart is LimeOut. It's sold in the plumbing area (hardware area) in Walmart. It contains Urea Hydrochloride something completely different then what you find in Limeaway. It does the job when Limeaway does nothing.
Wayne z.
Mountain Mama
N. TX
Posted: 10/12/08 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Just an FYI for anyone in the N TX/Dallas area...I found the liquid Calgon Water Softner at the Wal-Mart in Roanoke, TX (Hwy 377 & 114)!
DianneOK
Donnelly, ID
Posted: 10/12/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Does the fiver have a washer/dryer? If so, the sludge may be built up powdered laundry soap........
Dianne
Donnelly, ID
DataStorm
HAM WB6N (Terry)
2005 Teton 39' Frontier Grand
2003 Freightliner FL60
Life Member Good Sam
Escapees
Geocache..."RVcachers"
RV net Blog
 > Lime-Away
