RV.Net Open Roads Forum: General RVing Issues: Pull-Out Pantry Needed
 > Pull-Out Pantry Needed
anchor
Spring Hill, FL
Posted: 12/06/08 01:36pm Link  |  Print  |  Notify Moderator
Our RV did not come with a pull-out pantry, the wire basket kind. Trying to find out where to look. Our pantry is only 8" wide.
2002 Class C 31' Gulfstream
2005 36' Keystone Challenger 5er
2000 Chev 3500 1 ton crew cab dually
2014 Ford Fusion
Trawler and Sailing (Ocean & Gulf Cruisers)
Fulltimers
Present Hobby: Cameras
Residents: Florida Gulf Coast
magicbus
Nantucket Island, MA
Posted: 12/06/08 01:51pm Link  |  Print  |  Notify Moderator
8 inches is going to be very hard. I would try Google or HD or Lowes in that order.
Dave
Current: 2018 Winnebago Era A
Previous: Country Coach Allure 36
Greyghost
In Arizona for the Winter
Posted: 12/06/08 03:08pm Link  |  Print  |  Notify Moderator
I wasn't able to find anything in the 8" width that you're looking for. You may want to consider finding wire baskets that you could attached to drawer slides and build your own.
I believe that I've seen wire pullout pantries on Winnebagos. You could check with them. My Mountain Aire has individual pullout drawers in the pantry. The pantry is designed with pre-drilled holes in the side supports for adjusting the drawer height. I was able to purchase an extra drawer with slides from Newmar and installed it in a few minutes.
As stated already don't forget to check Home Depot and Lowes.
Pat & Roger Fisher
2005 American Tradition 40W
2012 Honda CRV EX-L 2WD,
Jewel, Clifford and Thor - Bouvier Des Flandres
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 12/06/08 03:11pm Link  |  Print  |  Notify Moderator
You might check out "ELFA" products. I made slide out pantry drawers using their products. I believe the narrowest they have is 9", which is what we used. They are component systems and you buy just what you need for you application. Great for undershelf also.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, ClearSpot 4G+,
http://www.kayepics.com
azbrewer
Northwest AZ
Posted: 12/06/08 03:23pm Link  |  Print  |  Notify Moderator
I made my own as the ones I found were to pricey. I used 2 100 lb drawer slides on the bottom and 1 laid down on the center top to locate it. Here is a picture
[image]and a link to the Full size picture
There 2 adjustable shelves, the bottom has sides to help keep it square
edited to fix links
* This post was edited 12/06/08 03:30pm by azbrewer *
2000 Holiday Rambler Vacationer
2007 Matrix Toad or
1986 Samurai
FMCA 2435S
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 12/06/08 03:37pm Link  |  Print  |  Notify Moderator
Definitely check Lowes. I installed several and seem to remember they had some narrow ones too.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
T&A
SE Michigan
Posted: 12/06/08 04:47pm Link  |  Print  |  Notify Moderator
I looked for a long time to find additional baskets for mine. I picked up some here.
CabinetParts.com
Terry
Terry & Amy
2004 Hurricane 30F on P32 Workhorse Chassis
2010 GMC Terrain (Towed)
2010 Ford Escape(Future Towed)
Where are we going.....and why am I in this handbasket?
pkunk
Questa, NM
Posted: 12/06/08 05:08pm Link  |  Print  |  Notify Moderator
CabinetParts.com
Terry
You 'could' use one of those, offset to the side with 6" baskets. I know of no other type that would work in 8" and I do cabinets for a living.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
Charlie D.
E. Texas-Orange
Posted: 12/06/08 06:08pm Link  |  Print  |  Notify Moderator
I made my own but had to install wood cleats to make them flush with the stiles of the openings. Used regular drawer runners from Lowe's.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
Alpenliter
Fulltimer: Wherever we are!
Posted: 12/07/08 12:45am Link  |  Print  |  Notify Moderator
I had the wire shelf type, but they didn't go all the way to the back of the cabinet and weren't wide enough to hold much. Since my width opening was only 6 inches wide I couldn't afford the space that side runners would take up, so I put runners on the bottom of the shelves. [image]
Since this picture was taken, I've added one more shelf and have tripled the storage capacity over the wire shelves. Here's a link to the full size picture. Clicky
My first Wife Linda, 45+years 2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade Bulletproof Diesel upgrades 1997 33' Alpenlite 400 Watts Solar Lifetime Good Sam Member #39644174 Escapees SKP#89882 Vietnam Vet '67-'68 [
Note: Due to invalid formatting, all formatting has been ignored.
