vkamp1
Englewood, FL
Good Sam RV Club
My '97 Dodge 3500 diesel has two 27H-XHD batteries. One tests good and the other has a shorted cell. The auto repair shop says I should replace both at the same time even though one is still good.
What do you recommend?
BillArf
I agree, replace both at the same time. That old battery can dramatically impact the new one and your system overall. Not worth the chance.
siggyd777
Northern Illinois
Replace both batteries,unless they are only a few months old!
Happy Trails
Siggy & Ursula
05 Kountry Star DP 3720,FTL XC
CAT C7 330HP,Allison MH3000
2005 Saturn VUE AWD V6 , Brake Buddy,Roadmaster XL,Falcon II
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 DP
FMCA 368283 , NKK 17385
horacebcupp
Johnson City, TN
vkamp1 . Ibid! The old one will pull the new one down.
2003 Foretravel, U 320
2003 Honda CR-V
Wherever I happen to park
There are two options....
One: when the cell shourted it took the good battery down below 12 volts
Two: A fuse blew and protected the good battery (I have never seen a rig fused that way)
I do not know of anyone who makes a true deep cycle Group 27. Marine/deep cycle is as good as I've seen. these are closer to starting batteries
I've taken the odd starting battery down to 10-11 volts.. and promptly bought a new one cause you can only do that one time on a starting battery and to date i've not gotten away with it.
Now DEEP CYCLE's... I've had survive harsh treatment. but never a starting or Marine/deep cycle type.
So I'd repalce 'em
I'd replace 'em with a pair of six volt golf car batteries if you have the room. You will pick up at least 10-20 percent more capacity and possible save some green in the process.. Sams or Costco have the best prices but you have to ask for them.. They can be hard to find.
ksg5000
Oregon
Ideally you want to batteries who have comparable ability which argues for buying two at the same time. With that said when I have problem with one battery I don't replace both unless the other one is marginal.
Kevin
Darrell
Somewhere in the US
Good Sam RV Club
Another way to look at it is like a tow chain. It is only as strong as its weakest link.
Darrell
PEACEFUL PATTON
"In His Grip"
A true friend is someone who reaches for your hand,
and touches your heart.
"FULL-TIMING & LOVING IT"
dclark1946
Richardson,TX,USA
wa8yxm wrote: There are two options....
Trojan SCS series available in Gr 24,27 and 30 something are true deep cycle batteries.
Dick
Dick & Karen
Richardson,TX
2007 KZ Spree 240RBS
03 Tahoe/09 F250 V10
TXiceman
(Near) Houston,TX
ALWAYS replace the batteries in pairs....
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Vulcanmars
Naples, FL
Good Sam RV Club
Replace both unless the other battery is less than six mounths old. Six months won't matter unless it was bad to start with.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
