RV.Net Open Roads Forum: Travel Trailers: Q: Bargman -> LED matching
 > Q: Bargman -> LED matching
Travel Trailers Related Tips
shenandoah75
Deland, FL
Posted: 09/05/09 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I was reading some of the prior posts on LEDs and i agree with some of the comments that the maxxima (M23015R/M23015Y) for markers... I'm assuming these mounting holes match up with those on the standard bargman 59s?
However, on my tail lights, guess i have a bigger issue. the lower back wall is slanted and thus i have bargman 92s installed with the a "wedge base". Are there any good recommendations here? Anybody fabbed their own bracket?
thx
-brad
05' Suburban K2500 8.1L w 3.73's
00' Catalina Lite 241FK (modified alot including bunk beds)
Jordan Ultima / Reese 1000lb? WD / Dual Cam / EU2000 / (2) T105s
TankerDude
West of Middle Earth
Posted: 09/05/09 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I swapped out all the markers and tail lights for LED's several months ago. Ordered everything online. Marker lights lined up perfectly, as they're made as a direct replacement.
On the tail lights, I ordered a LED "bulb" that replaced the standard 3157. I was a little skeptical at first concerning the "bulb" replacement for the tail lights. But, after installation, the tail lights and turn signals were significantly brighter, even in the sunlight!
Going the "bulb" route on your tail lights would eliminate the problem of finding or fabricating a wedge to allow the lights to be parallel with the ground.
Here's a link to the 3157 bulbs.
Here's a link to the LED Bargman marker lights.
Here's a link to the 1157 direct replacement bulbs.
* This post was last edited 09/05/09 10:33am by TankerDude *   View edit history
It doesn't matter to me if you don't own a Mac.
It should matter to YOU that you're still tethered to Microsoft.
2004 Ford F350 PSD 6L 4x4 Crew Cab.
2007 Jayco Eagle 322 FKS.
Camping with DW Terry,
Bobi-Sue and Billy-Joe,
Westhighland White Terriers
shenandoah75
Deland, FL
Posted: 09/05/09 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
When you swapped the markers, did you use the gasket or butly tape / something else to seal?
ejbrandley
Entirely too young to be a
Posted: 09/05/09 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
when i swapped out my markers i used houshold window caulking the kind that doesnt dry hard so far so good with the lights i put in
but i didnt change the brake lights either because of the same reason original poster described but i did something different i bought some led 3rd brake light strips and wired them in to the brake wire they work good for the brake lights but they really dont have enough time to energize with theturn signals so i guess i might just replace the bulbs
TV 1997 GMC SUBURBAN, 92 Mustang Rag Top
1986 34ft Nomad
Eric 33,Tammi 39,Anthony 14,Julia 12,Jason 11,Briana 8,Ashley 6,Robert 4
TankerDude
Posted: 09/06/09 05:43am Link  |  Quote  |  Print  |  Notify Moderator
The markers I ordered are on the same website those links will take you to. The markers come in red or amber, and are completely sealed. No caulking of any kind is required to keep water out of the markers themselves, but you may want to use something to seal the screw holes on the trailer. I used regular silicone in the holes, then just installed the markers. Since the silicone will not be exposed to sunlight and weather, it should last a good long time.
Just be careful about reinstalling the screws. Not every situation will be like mine, I know. Not one of those screws went into any wood or metal. Just the fiberglass siding. I thought I was going to have a problem with the threads stripping out of the holes, but I was lucky I guess.
In retrospect, maybe I should have put a little dab of silicone on the back of each marker before it was installed. That may help long-term if those screw threads should decide to let go.
trail-explorer
NM
Posted: 09/08/09 05:53am Link  |  Quote  |  Print  |  Notify Moderator
When I installed my 23015 series lights, I pit a dab of silicone in the screw hole, and use putty around the hole on the back of the light, then like mentioned above, put silicone (or something similar) around the light.
mount hole spacing on the 23015 is 3", which is pretty common for other lights used in the RV industry.
Mr. C
Virginia, USA
Posted: 09/08/09 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
The tail lights on our TT are on wedge bases. I replaced the old Bargman #92 lights with the series 07 LED lights. They look great. The 07 has a rounded top, and it sticks up above the base by about 3/4". Caulk took care of that problem. 3 of the 4 original screw holes lined up...didn't need the fourth one. Also replaced the marker lights with Bargman LED direct plug-ins. They were a little pricy, but very easy to replace.
Dave........
2006 Coachmen Captiva 271RKS "Pressure Relief 2"
2005 Silverado 1/2 ton extcab 4x4
factory tow pkg 5.3 / 3.42
reese dual cam
Knowledge is good.
shenandoah75
Deland, FL
Posted: 09/08/09 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Mr. C - if i understand correctly, you used the 92's wedges and then the 07's on top (including one on the 07's with the license plate bracket)? Does the 92 wedge stick out behind shorter side ?
any chance you have pic
Mr. C
Virginia, USA
Posted: 09/09/09 07:17am Link  |  Quote  |  Print  |  Notify Moderator
The shorter side of the 07 is the same height as the wedge. The taller side sticks up above the wedge, but not by much. I used one with and one without the license plate bracket. I'll try to post a pic when I get home from work.
Dave...
Mr. C
Virginia, USA
Posted: 09/09/09 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
hope this works
