califRVers
Santa Rosa, California
Hi there!
I am going to purchase an electric tongue jack for my hubby and I wanted to know what the expert opinions are as to whats a good quality electric tongue jack for our 32' Outback.
Whats a good brand?
Longevity?
How easy is installation?
How easy are they to use manually in case of a malfunction?
Do you have a photo of yours installed?
Thank you! :-)
Tim and Julie
Our Blog | Our Outback
2010 Outback 260FL 31'9" GVWR 7800 - Atwood 3500 - Eaz Lift Elite - 2 Interstate 6V
2006 F150 4x2 Supercrew Lariat 5.4L Triton V8 3:55 LS 139" WB 20,000K Miles
Prodigy - Flowmaster - K&N Filter
crab80
Virginia`s Eastern Shore
Barker VIP 3000 or 3500-Made in USA, Very easy to install. There is a hand crank for emergency use, I have not used it yet. I have heard some members say they last a long time, I have only had mine a few months so far so good. I have no picture, but it is about as attractive as a tongue jack can be. Good luck.
2010 Jayco 28BHS
2004 Chevy 1500 Ext.Cab 5.3L, 3.73, Bilsteins
Reese Dual Cam
Prodigy P3
Barker 3000 jack, 22 Blue tote
SteveRankin
Sequim, WA
There seem to be two major brands; Atwood and Ultra Fab.
The most obvious difference between the two is the Atwood has a white motor housing while the Ultra Fab is black wrinkle paint.
Most TT's seem to come with Atwood, which indicates that they cost less for the RV manufacturer. We've had several Atwoods and one Ultra Fab. They all worked just fine, except the Atwoods make an awful racket compared to the Ultra Fab which sounds like a fine sewing machine by comparison.
Both install equally easily: just slip the jack into the hole in the trailer A-frame, install the 3 bolts, then run the wire to a batter POS+ terminal. Voila!
Here's a link to a page on installing a tongue jack.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 24-5N
2007 Ford F350 4X4 Crewcab LB 11.5K GVWR
PullRite 18K SuperGlide
Our Arctic by RV trip
Our Beaver motorhome Technical page
The Arctic Circle
JJMorrocco
Edmonton, Alberta, Canada
It would be very hard to go back to not having one, one of the must haves on any trailer I own from now on.
I might recommend a black or other colored (non-white) model. Mine has some serious discoloration after just two years.
Sorry I don't recall the make or model.
PUMA 31BHSS
Edmonton, Alberta Canada
pete42
Ohio
Barker there are several threads on this site most all jacks are great choice to buy is hard Barker 3500 seems to be number one
califRVers
Thank you for the advice! One more question, I notice some are 2" and 2 1/4? What is the standard size? Our Outback is not stored at our home so I cant run out and look.
Thanks again!
jspringator
Versailles, KY 40383
I had a Barker. It lasted 2 seasons. The manual crank assembly was junk. I currently have an Ultra Fab, and it has gone 2 seasons. It is starting to get noisy. It probably needs some grease. These things do last longer when covered. I think I left mine uncovered too long and it washed out some of the grease.
They aren't hard to mount, but I had to make up an length of cable with a lug end to attach to the battery.
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion LTD 3.73 LSD, V-10, 2WD
Honda EU2000 and EU1000 gensets;
2000 watt Tripp-Lite inverter/charger APS 2012
1989 Bayliner Ciera 2150
Saturn SD365 inflatable, 15 hp 2 stroke Yamaha
LarryJM
NoVa
pete42 wrote: Barker there are several threads on this site most all jacks are great choice to buy is hard Barker 3500 seems to be number one
I would have to agree a black colored Barker 3500lb will do the job nicely and hold up well from everything I have read.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
sonicsix
Jemison, AL
Good Sam RV Club
Barker 3500. Awesome customer service. Very easy to install. Just pop off the level on top to use manual crank. Pic shown. I love my Barker 3500!
Why We RV | Our Lighthearted Blog | Our Big List of Mods | The RVer's Library
califRVers
Sonic thanks for the photo, is that box behind the propane your battery set up? 6v or 12v? very nice, I'd love to know about the details of your set up in the photo if you don't mind..
EDIT: never mind I just saw your link to your mods! :-)
edited 10/26/09 05:51pm by califRVers *
