RV.Net Open Roads Forum: Class C Motorhomes: Water leaks in Cab Floor
 > Water leaks in Cab Floor
Class C Motorhomes Related Tips
gaysharp
Dawsonville GA
Posted: 10/29/09 11:10am Link  |  Quote  |  Print  |  Notify Moderator
I have an 1988 Minni Winnie 26 footer. It is in excellent condition but there is water under the mats on both the driver's and passenger's sides. The RV is currently at a Camping World where they are attempting to find the leak. They have performed the usual whatever that they do and have been unable to find any leaks. Obviously there is one due to the water under the mats. I am going to attempt to sell it. It has only 32,000 miles on it and we have done considerable maintenance on it as well as added levelers, automatic antenna, gas/electric water heater; exhaust fan in bedroom. It is really important that I locate this leak in order to sell it. Any suggestions?
tatest
Oklahoma
Posted: 10/29/09 11:24am Link  |  Quote  |  Print  |  Notify Moderator
A/C drain blocked or heater core cracked.
Loose or cracked ventilation ducts.
Any of the grommets that come through the firewall.
This is something a Ford dealer might know more about than a RV repair shop.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
gaysharp
Dawsonville GA
Posted: 10/29/09 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I need all the suggestions I can get.
marvh
Tampa area
Posted: 10/29/09 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
If it isn't overheating and calling for the radiator to be refilled, it ain't the engine. I would have to know if you drove it in a recent rainstorm. Maybe the doghouse is not sealed properly. Marvh
j-d
Sunny Florida USA
Good Sam RV Club
Posted: 10/29/09 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Our '83 E350 had rust holes in the bottom of the firewall at the passenger's left toes, and through the upper corner of the firewall where the inside of the fenderwell met the firewall, up beyond the passenger's right toes. There was rust damage under the battery and in the fenderwell behind the battery. I think a previous owner had a battery that gassed all the time. I found our leaks by pulling the carpet back. Repaired them with expired license tag material, body sealer and pop rivets.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
gkainz
Arvada, CO, USA
Posted: 10/29/09 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
you may also want to check out and post this on the Ford Truck Enthusiasts forum: http://www.ford-trucks.com/forums/index.php in the appropriate topic area - lots of very knowledgeable folks over there, as well.
Something in the back of my brain is niggling me with "hood cowl vent" but that might just be the nagging reminder that I have yet to fix the leak in my Jeep ...
Greg
'83 Tioga 27' Ford E-350 460
'97 Dodge 2500 CTD 4x4 in need of a TC
Stennis
Starkville, Mississippi
Posted: 10/31/09 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Could it be related to a leak from the chasis air conditioner? We had that problem with a W-22 chassis but it only occurred soon after starting the A/C with high humidity in the cabin.
canter
Maryland
Posted: 10/31/09 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
This happens in my ford card. There are drain holes near the windshield wipers to drain the water off the windshield and sometimes they get clogged with leaves and stuff. If they are blocked, water will run into my car behind the gas pedal and onto the floor. Don't know why the water goes inside the car, but I know to keep those drains clear.
csp et2
Waterford CT
Posted: 11/01/09 05:15am Link  |  Quote  |  Print  |  Notify Moderator
Check the door gaskets... We had a leak on a new Crown Vic and Ford found out that it was the door gaskets. Ford replaced them, and no more leak.
Bob
j-d
Sunny Florida USA
Good Sam RV Club
Posted: 11/01/09 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Water getting into a car...
We had one where debris in the cowling vent area diverted water to run into the cabin instead of down the overboard drain. Had to remove wiper arms and vent cover to access it.
