RV.Net Open Roads Forum: Class C Motorhomes: Front End Clunking Sound Seneca 35GS
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Front End Clunking Sound Seneca 35GS
Class C Motorhomes Related Tips
Seneca 35GS
whittier
Posted: 10/30/09 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
From time to time I hear a clunking sound from the front suspension of my '06 Jayco Seneca C5500. Repalced the stock shocks with Koni FSD shocks but the sound is still there. It does not happen 100% of the time just ocassionally. Has anyone else had this problem? Is something loose, or is it the way the suspension is designed.
Gale Hawkins
Murray, KY
Posted: 10/30/09 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
While a different vehicle my Blazer did this when I first got it with 102K miles on it but after I had it greased it stopped at once and has not returned.
billystoys
Alberta
Posted: 10/30/09 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Mine also does it, seems its the front spring (can`t quite remember the technical term ) unloading. Noise on mine is only at very low speeds and usually going over a bump while turning. Very common on this chassis.
tomakat
Southern California (Mission Viejo)
Good Sam RV Club
Posted: 10/30/09 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, mine does the same thing at low speeds over bumps and while turning also. I wish there was a way to fix this, but if that's normal, then it's good to know.
2008 Bigfoot 25B175G, Equalizer Sway/WD, Prodigy P3 brake controller, Honda EU2000i Generator
2007 Porsche Cayenne S (v8)
ronfisherman
SE Michigan
Good Sam RV Club
Posted: 10/31/09 03:28am Link  |  Quote  |  Print  |  Notify Moderator
Mine does the same. Front springs clunking.
bgie
MA
Good Sam RV Club
Posted: 10/31/09 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Mine too. Annoying but hopefully harmless. There is comfort in numbers.
Bill
Bill and Karen
Chloe, the Golden Retriever
2006 Jayco Seneca HG33SS
Host Rider
Horsham, PA
Good Sam RV Club
Posted: 10/31/09 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Seneca 35GS, If you are feeling more of a feedback (clunking)thru your steering wheel and into your hands, and not actually a loud noise, it is very likely your steering shaft. It is a VERY common problem on the Chevy heavy duty's and all of mine have done it at one time of another and I have owned nine or ten of them. It could also be a drag link (do a search) as well that is a little loose and also very common. These, as mentioned before, can just simply be regreased and that takes care of the problem usually for a long time. There are aftermarket shafts that take care of the problem permently and I don't think they are too expensive (a company Borgeson makes them I think). I have 8,000 miles on my Host and I am starting to feel it as well (FORD F550) so it may be a very common problem. Hope this helps, Regards, Paul
2009 HOST 300 Motorcoach 4WD
ldekryger
michigan
Posted: 11/01/09 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Our '08 Senneca 36FS does the same thing. The GM dealer found a loose cross member or something of that sort, and after tightening it, the clunk is a bit less but still noticeable, and it drives me crazy. Good to hear I have company .......
racnacr
Pa
Posted: 11/03/09 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Mine too, local truck mechanic said it's common. Nothing worn or broken, just a sound that chassis makes.
05 Gulf Stream 6316
"Super James"
Mile-High-Endura
Colorado
Good Sam RV Club
Posted: 11/04/09 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I've heard it with mine also.
Jeff
2005 Gulf Stream Endura 6340 8.1 gas
2000 24' Pace Shadow Limited w/ Husky Equilizer Hitch
1987 Jeep Wrangler YJ PS, PB, Automatic, Factory Air
