joeandsueavery
KY
Ok , we tried Class A travel and falied ...my fault ' i'm too nervous driving in it .
So....we have bought a lite weight travel trailer .
we have a 2005 dodge ram , quad , full size truck and i see locally a reece weight distribution hitch for sale which is 1,000lb tongue and 12,000lb weight .Our trailer is 670 lbs/6100 lbs so i know the hitch is strong enough .
now my dumb question
Do i have to have a certain weight distribution hitch or can i buy this Reece one i've seen ?
Thanks in advance .You guys have helped us a lot
bob213
Fresno, CA
Good Sam RV Club
If you want sway control with your weight distribution, then you would probably want to look at an Equalizer or Reese "Dual Cam". Otherwise the Reese you are looking at will probably do the job.
Golden_HVAC
Fulltime, CA, USA
This one does seem a little to heavy for your application. The weight distribution bars are rated to a certain strength, and they are spring bars, so getting ones that are two stiff could make adjustments a little more difficult.
But it is doable. Just don't overtighten them.
Good Luck,
Fred.
Chuck&Gail
In the Colorado Mountains
How did you get the weights your quoting, did you actually weigh your FULLY LOADED trailer? If so, you need more weight on the tongue. A good target is 13% of the FULLY LOADED weight.
So IF it really weighs 6100#, you want 793# on the tongue. A 1000# unit should be fine IF IF IF you add sway control.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
WoodLark
South Carolina, USA
I just got into the travel trailer world myself. My truck is a Dodge 1500 and my trailer is in the same general weight range as yours. After looking at the various hitches available, I purchased the Reese SC Pro from etrailer.com. It is rated at 1100/11,000, and I couldn't be happier. It was easy to install following the very clear directions from the manufacturer(need the right size wrenches though) and works perfectly. The trailer rides level and there is absolutely no effect from passing semis on a two lane highway (sway control is included).
As a side benefit, it is less expensive than some of the others and shipping is free (which is a good deal, because this thing is HEAVY).
Jerry9n
SE Michigan
I second the Pro Series SC. Mine is lighter at 750# hitch, but the whole setup is great. Easy to put on and use. Had a dead weight hitch before with a friction bar. No comparison.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Voyager
HTT Mods
sonicsix
Jemison, AL
Good Sam RV Club
I have the Equalizer brand hitch with built in sway control... and I love it. Very easy to hook up and it does a great job. I like the bars... no chains to fiddle with.
As others above stated, make sure you get sway control no matter what hitch you get.
Why We RV | Our Lighthearted Blog | Our Big List of Mods | The RVer's Library
rayman4910
Maryland's Eastern Shore
Good Sam RV Club
The reese hitch your looking at is fine. I have a 2006 dodge dakota and pull a 2007 amerilite by gulfstream. I had a terrible sag I put the reese distribution hitch on and now my headlights are back at the rite height. the only problem I have is it makes the creeking sounds when turning.
vernj4
Kalamazoo, MI
Good Sam RV Club
"the only problem I have is it makes the creeking sounds when turning"
A snapping sound means the dual cams are working!
NORCALer
Sacramento, CA
another vote for the equal-i-zer hitch and it can be purchased for $459 to your door (free shipping).
http://www.rvwholesalers.com/catalog/equal-i-zer-hitch-1000-10000lbs-trailer-weight-90-00-1000.html
best price and customer service around, trust me I looked.
Don't forget to order the ball and lube.
2010 Pacific Coachworks Tango 309BHSS
2008 Toyota Sequoia SR5 5.7 V8 4X4 4.30 6 speed.
10K Equal-i-zer Hitch by Progress MFG. INC.
Prodigy Brake Controller
