RV.Net Open Roads Forum: Travel Trailers: screwing in the walls
 > screwing in the walls
Travel Trailers Related Tips
jeepsailor
Buena Park, CA
Good Sam RV Club
Posted: 11/09/09 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Well my friends it's been about 2 years now and I think its time to think about finding the best way to drill and or put screws in the walls to put stuff up. so my question for all of you that have done it. How, Where, and your advice to do it?????
I have a rockwood (forest river) mini lite TT. 1809.
skipnchar
Topeka Kansas USA
Posted: 11/09/09 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
We NEVER use normal screws to mount anything on the walls unless there is a backing behind the wall. MOST items can easily be mounted with Command strips which means they can also be removed easily with no damage done. for items that are meant to be PERMANENT then using Toggle bolts on a hollow wall works just fine and NEVER comes down or strips the hole out. Good luck / skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
kknowlton
Wisconsin Border Country, IL
Posted: 11/09/09 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto. We've used Command strips with success. Trailer walls are just not set up to hang things using traditional home methods.
In The Wind
Michigan
Posted: 11/09/09 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Mighty Putty, Gorilla Super-glue, Industrial-strength Velcro...
click on our blog to see what we've done so far...towel bars in bathroom are holding strong (one with Mighty Putty, one with Gorilla glue)...Good Luck!
http://www.AdventuresInTheWind.blogspot.com
2010 Forest River Work & Play - 30'
2009 Nissan Titan 4x4
2001 H-D Road King
"It is only with the heart that one can see rightly, what is essential is invisible to the eye."
- Antoine de Saint-Exupery
Wrace
Seattle WA
Posted: 11/09/09 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hope it's ok to add my question in this thread as it has to do with fastening things to the wall. I need to put up two corner shelves in the bedroom just above the head of the bed to hold my wifes and my cpap machines.
Is it possible to buy the faux panel sticker covering that goes on the pressboard that is used in the trailer cupboards, so the shelves look like the rest of the rig? Or am I better off buying a pre-made corner shelf that sort of matches the interior paneling.
These will need to be mounted pretty securely as the cpap machines do have some weight to them. Are toggle bolts the best way to go? I am familiar with residential toggle bolts that use the spring action wings and long screw/bolt. Do you use the same type for the rv except with a much shorter screw to accommodate the thin wall thickness?
Thanks
NanciL
Bakersville, NC, USA
Posted: 11/10/09 04:27am Link  |  Quote  |  Print  |  Notify Moderator
I did it on my last TT and just finishing it on my new one.
I added three bathroom towel racks, and a five foot long clothes hanging rack.
I make up oak backing plates that match the original ones that came with various things in the TT. Then I glue these to the wall using two brass screws that are just long enough to penetrate the thin wall paneling.
Naturally I drill holes in the oak backing plates for the screws, but I don't drill any pilot holes in the wall. I put a coating of glue on the back of the backing plate and then using force screw the screws into the wall paneling. All the screws are doing is acting as my clamp until the glue dries. the reason for using brass is for attractiveness.
The next day after the glue is dried I can then screw whatever I want into the oak backing plate.
I have used this exact same method to install shelf cleats to all our wardrobes to convert them to shelves, but naturally I don't use a backing plate. Just the wood strp shelf cleat and el cheapo screws.
Not a one has ever come off the wall in our first TT which had over 30,000 miles on it including many rough roads in Alaska.
Jack L
Jack & Nanci
JIMNLIN
Big Cabin, OK
Posted: 11/10/09 05:08am Link  |  Quote  |  Print  |  Notify Moderator
I use self threading hex or phillips screws on anything that hangs. It is a mobile unit so if its heavy I find a stud for longer screws to hold the weight. Glue or sticky tape can mare the wood panel finnish. A screw hole can be filled or repaired easily. I've added coat hangers all around the bath room for wet coats/jackets/etc.
"good judgment comes from experience, and a lot of that comes from bad judgment" Will Rogers
'03 2500 QC Dodge/Cummins HO 3.73 6 speed manual Jacobs Westach Linex
'97 Park Avanue 28' 5er with two slides 16" BFG Commercial LTs
JJBIRISH
Butler, PA, USA
Good Sam RV Club
Posted: 11/10/09 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Use a wall molly not a toggle bolt
Love my mass produced, entry level, built by Lazy American Workers, Hornet
lovechipps
Posted: 11/10/09 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, the command strips work great until the wallpaper pulls away from the wall! This happened to us this summer when we were using a command hook for our broom. The wallpaper bubbled and stretched away from the wall about the size of a golf ball and I smoothed it out the best I could but you can still see a small wrinkle. I would advise against using them for anything if you are using them on wallpaper. Oh and we have and '08 Jayco Eagle.
JJBIRISH
Butler, PA, USA
Good Sam RV Club
Posted: 11/10/09 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Wall molly’s ( centre & right) come in lengths for paneling…
