RV.Net Open Roads Forum: Class A Motorhomes: Back Up Camera Repair
 > Back Up Camera Repair
BobR
Aurora, Illinois
Posted: 11/10/09 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Sony SSC520AM camera in need of repair or replacement. Any suggestions on sources who repair the cameras?
DtBt
Saint Leonard, MD
Good Sam RV Club
Posted: 11/10/09 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried here for a replacement?
Dennis and Barb
1999 Monaco Windsor 40 SS
2002 Chevy Avalanche toad
6string
Springfield, Illinois
Posted: 11/10/09 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if you mean the camera or the monitor. My monitor went out. I called all around, found out it was discontinued and the new model wouldn't fit into the dash opening. Ended up calling a local TV repair shop and they fixed it for $20. Bad diode. Hope this helps.
BobR
Aurora, Illinois
Posted: 11/10/09 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
The camera is what I think is bad. The monitor powers up. The picture got wavy and then went out along with the sound. I appreciate the link but it is for a repair manual. I am in the same boat as 6string with a built in monitor and camera housing which limits options on replacements.
bigbubba1959
Illinois
Good Sam RV Club
Posted: 11/10/09 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
hi you want want to speak with these guys....... they were easy to work with when I had issues with my system
RV CAM
if once you dont suuuceedd
If once you deont succeed
If once you dont succeed try tryyyy
If once you dont' succedd
Ok if once you dont succeed just freaking DO IT!!!!!!!!!!
corgidad
Virginia
Posted: 11/10/09 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I second bigbubba's suggestion, contact Tim at RV cams he was very helpful to me and many others. He is great to deal with and will fix you right up
Bea PA
Waynesboro, PA, USA
Good Sam RV Club
Posted: 11/10/09 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
You didn't say what rig you have but on our 2004 the Sony was junk, replaced from Tim at 3 years.
1rooster
Warrenton, VA
Posted: 11/11/09 07:14am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem with my Weldex camera (06 Fleetwood Discovery). What I did is remove the rear camera from the coach and plugged it directly into the front camera. It worked. Then I resolved the cabling problem. If you need further info, please PM me.
BobR
Aurora, Illinois
Posted: 11/11/09 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the suggestions. My motorhome is a 1991 and the backup system is original. I did pull the monitor out of the dash and the 4 pin cable to the camera was plugged in properly. It is a one camera system so I don’t have the option of trying the camera at another location. I guess I will try to find a local repair shop.
