sdadams
I discovered a very miniscule leak around the base of my toilet this morning. It seems to only leak when the pedal is pressed and not from being uner pressure. Do you think the bolts that hold it to the floor just need to be tightened or does it need a new seal? I am not familiar with the way RV toilets work so any advice would be appreciated. I believe it is a Thetford toilet and it is 7 months old.
Thanks for your help.
edited 11/13/09 07:32am by sdadams *
enblethen
Moses Lake, WA USA
Good Sam RV Club
More likely to be the water ball valve then the seal.
Make and model of toilet.
Does the water remain in the toilet after flushing? Yes, means water valve for sure.
Bud
Suzuki XL7 pushing Pace Arrow
sdadams
I will have to get the exact make and model. Yes, the water does remain in the bowl. Can you replace a ball valve or does the entire toilet have to be replaced?
Gary n Vicky
Piney Woods of Texas
Good Sam RV Club
I would be intrested in this fix. Not that I'm having a problem but, this information may come in handy some day. Please keep us informed..
08 Silverado 2500HD, Prodigy brake controller, Trifecta tonneau cover, TPMS by Truck Systems Tech.
09 North Trail 31BHD
55 (Me)Retired USAF
53 Bird Loving Wife
95 Computer Geek Grandson
Be a leader, Be a follower, or Get Out of The Way!
bldrbuck
Boulder, Colorado
Good Sam RV Club
Does it leak when filling the bowl? That could be a leak at the fill valve. If it leaks when dumping the water that could be the seal. Tightening the mounting bolt may help this. You can buy seals and valves at most RV parts stores, even Walmart has some. Good luck.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
enblethen
Moses Lake, WA USA
Good Sam RV Club
The valve can be replaced. Depending on model how easy. Most Thetfords need to have toilet removed for ease on installation.
If yours has the cable for operation, inspect them closely as they get fraid an will break. If fraid replace while you are there.
skipnchar
Topeka Kansas USA
WE had a similar type leak last summer (or thought we did) because we would find a small amount of water right at the base of the toilet. No signs of water leaking from above but we eventually found that there is a tiny O ring sealing the outlet tube from the water module. The O ring has become unseated and allowed just a single tiny stream of water to escape with each flush and it took several minutes for the water to reach the toilet base and be seen. Re-set the O ring and no more water leak. Good luck / skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
sdadams
Skip, would that o-ring be at the fresh water conection to the water module and if so, is it located at the back of the toilet?
Thanks.
enblethen
Moses Lake, WA USA
Good Sam RV Club
There is an o-ring between the water valve and the toilet flush assembly. It could be a Skip suggested.
sdadams
Thanks, I will tear into it this afternoon.
