RV.Net Open Roads Forum: Tech Issues: Lubricating the winegard antenna question
 > Lubricating the winegard antenna question
Terrydactile
Bessemer, Alabama
Posted: 11/18/09 02:35pm Link  |  Print  |  Notify Moderator
Looking through the op instructions it mentions lubricating 3 items on the antenna.
1) The elevating gear.
2) The bearing surface between the rotating gear housing and the base plate.
3) The rubber quad ring.
I can see how to lube #1 & #2, but how do you get to #3 the rubber quad ring? Do you have to take out the worm gear assembly?
Anybody have experience doing this?
Scott & Theresa Boyd
2 Daughters (Cassie & Brittany)
1 Furkid (Ella, a Basset Golden mix)
2008 Keystone Passport 280BH
2013 F 150 Supercrew EcoBoost XLT
crickeydog
Marietta, Ga.
Posted: 11/18/09 03:04pm Link  |  Print  |  Notify Moderator
Annually, I squirt a abundance of WD-40 on anything that looks like a hinge or friction point on our Wineguard antenna. WD-40 will it's way down into anything that moves. Our antenna has alway's worked like a charm.
Happy camping!!! Se ya'll down the road!!![emoticon]
USAF RETIRED 02/1992
DOD RETIRED 04/2014
D/W US GOV/DOJ/DEA RETIRED 10/2010
PULL DOG:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT
2004 HOLIDAY RAMBLER PRESIDENTIAL 30' SCD 5'ER
Wheel Estate
Emery, S.D.
Posted: 11/18/09 03:12pm Link  |  Print  |  Notify Moderator
page 5 is where the lubrication instruction appears in the guide.
my other advice is to put silicone grease on the underside of the 'boot' that the cable passes through. in all my years that has been where I've had a leak, and easily cured
manual
Rick & MaryAnn
drive a Phaeton with
SMI brake stopping a Jeep toad
skipnchar
Topeka or somewhere else
Posted: 11/18/09 07:06pm Link  |  Print  |  Notify Moderator
I just sprinkle a little light weight machine oil around the inner parts and use flake graphite to lube the outer ones (don't ever want to get petroleum products on the roof if you have rubber). Never paid much attention to just WHAT I was lubing but everything would work very smoothly when I finished [emoticon]
dougrainer
Carrolton, Texas
The manual says to remove the shaft/worm gear to lube. I have found that by removing the top plastic nut on the shaft and using a tube extension on the spray grease, you can hit the plate where the rubber seal seats and that lubes it. Doug
Terrydactile
Bessemer, Alabama
Posted: 11/18/09 07:26pm Link  |  Print  |  Notify Moderator
Thanks for the replies.
I was just concerned about lubing the rubber washer because the manual says it will keep it from drying out and causing a leak. I guess when I lube the gear it will spread to the washer.
Well aware of petroleum products and rubber roofs. Will just use pure silicone as indicated in the instructions.
Ozlander
Rose Hill, Kansas
Posted: 11/22/09 03:04pm Link  |  Print  |  Notify Moderator
I stuffed mine full of dielectric grease years ago and forgot about it.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
karead
Ottawa
Posted: 11/22/09 03:12pm Link  |  Print  |  Notify Moderator
DO NOT use WD-40! Only silicon spray is to be used.
Direct from the Winegard website...
You will want to lubricate the quad ring 3-4 times each year to keep it from getting brittle. To lubricate this ring just spray the gear housing on the roof with a silicone spray lubricant. DO NOT use WD-40 as it is a solvent and will eat your gears.
"Beer. It's the reason I get up every afternoon."
karead
Ottawa
Posted: 11/22/09 03:16pm Link  |  Print  |  Notify Moderator
See page 5 for detailed lubrication instructions...
Winegard operation manual
Charlie D.
E. Texas-Orange
Posted: 11/22/09 05:01pm Link  |  Print  |  Notify Moderator
I didn't see it in the instructions but look for a small black rubber plug on the top. Remove it and spray silicone in the hole. That is how you lubricate the sealing o-ring. Be sure to reinstall the rubber plug so water does not get in.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
