RV.Net Open Roads Forum: Class C Motorhomes: Scissor Jacks
 > Scissor Jacks
jozman
Massachusetts
Posted: 05/04/11 04:02pm Link  |  Print  |  Notify Moderator
Hello everyone! I was just wondering if any of you have/use scissor jacks on your coach? I was thinking of welding two to the rear of my Four Winds for better stabilization. Comments?Concerns?Questions? As usual any and all feedback is welcome....
30' 2006 Four Winds
"The Mighty B"
6.0 Vortec
Jozman
Dusty R
Charlotte Michigan 48813
Posted: 05/04/11 04:53pm Link  |  Print  |  Notify Moderator
Yes I have a pair. We had an '88 22' class C which I put the Quick to Ground one on. Which is more of a beam with jacks on the ends. I feel that the stabilizer should be as close as practical behind the rear axel. We now have an '03 24' class C. Because of the larger gas tank I could get the QTG beam as close the the rear axel as I wanted so I put on a pair of the scissor jacks. I would rather bolt them on than weld.
Last I looked there were drive motors that can be put on the scissor jacks. That would make them all the more interesting.
I only put them down if we are going to stay put for a few days.
I may try to rebuild the QTG beam and put it on the front, but we have a front hitch on to attach our bicycle to.
Dusty
fisher60
Plant City, Florida
Posted: 05/04/11 05:12pm Link  |  Print  |  Notify Moderator
I have 4 bolted on. Work great at stabilizing and help somewhat at leveling.
'01 Dutchman Express 28A, Borg Chrome Dually Valve Stems, Pacific Dualies Wheel Simulators, '06 Tuscon, 2014 FLHTCUTG
Good Sam Life Member
hohenwald48
Nashville, TN
Posted: 05/04/11 09:13pm Link  |  Print  |  Notify Moderator
I have 4 bolted on.
Welding is a little risky and bolting is just as good and takes about the same amount of time.
When seconds count, the police are only minutes away.
2015 Open Range 216 RBS
2013 Nissan Armada Platinum
JAXFL
Jacksonville, Florida, USA
Posted: 05/05/11 05:28am Link  |  Print  |  Notify Moderator
I have 2 on the rear that the dealership installed with bolts. They are solid but I see very little inprovment in stabilizing the 32' MH.
ramzfam
Appomattox, Va
Posted: 05/05/11 09:13am Link  |  Print  |  Notify Moderator
My RV came with a bolt on scissor jack system from BAL
BAL SJ System
Because of the way a Class C is attached to the chassis, there is just so much stabilization that you can do. The jacks help steady the coach noticeably when compared to no jacks and will provide 3 or 4 inches worth of leveling. Major leveling still require blocks.
Have RV....Will Travel "> ">
2007 Forest River Sunseeker 2860 LTD
2000 Jeep Wrangler Sahara
mgirardo
Brunswick, GA
Posted: 05/05/11 06:29pm Link  |  Print  |  Notify Moderator
Ours has 2 slides, one on each side of the Motorhome. We use these, except ours are 7,000lbs each. With the slides, I find it best to use them on the corners of the body instead of on the frame. I started using them on the frame and the motorhome was still a little bouncy when climbing into the coach or if one of the kids was moving around on their bunks which are on the bedroom slide. Once I moved them to the corners of the body, the motorhome was a lot more stable.
Although the scissor jacks would be easier, with our motorhome the Stack Jacks work better. If you don't have slides, the scissor jacks would probably be fine.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
kaz442
NJ
Posted: 05/05/11 09:02pm Link  |  Print  |  Notify Moderator
I have two scissor jacks in the rear of my unit. Are they used more for the control of rocking and such or do you use them to level the MH?
JKaz
1989 26' Jayco class C E350 460cu
JRandall
Fresno, CA
Posted: 05/05/11 06:41pm Link  |  Print  |  Notify Moderator
Yes...just did this actually. Welded the Jacks on to a beefy piece of angle which I then mounted just behind the rear axle. Still not totally stable, but much better. Looking to mount to more in front if I can figure out how to do it.
Gene in NE
Omaha
Posted: 05/05/11 10:33pm Link  |  Print  |  Notify Moderator
JRandall wrote:
...Looking to mount to more in front if I can figure out how to do it.
The second to seventh pictures show what (B-Plus) Dario did to the front of his Trail-Lite with a Chevy chassis -
Click Here. You can see that he uses 1 jack (I believe an electric 5,000 lb one) that can lift the front wheels off the ground.
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
 > Scissor Jacks
