RV.Net Open Roads Forum: Travel Trailers: Reese Dual Cam
 > Reese Dual Cam
aarond76
home
Posted: 06/13/12 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I currently am towing a 2006 Cherokee 32B with a Reese Weight Distribution with the add on friction sway control. Thinking about getting the Reese Dual Cam sway control. Once I install the Dual Cam can I still use the add on friction sway for added safety or just use the Dual Cam alone?
For what its worth towing with a 2002 E350 van w/ V10.
tbrowne
Springfield, OH
Posted: 06/13/12 10:12am Link  |  Quote  |  Print  |  Notify Moderator
You won't need the friction control with dual cam. Not a good idea!
Terry Browne
ScottG
Bothell Wa.
Posted: 06/13/12 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Get rid of the friction unit.
Scott, Grace and Wesly
H0NDA eu2000i
C.B.
APPLETON WI USA
Posted: 06/13/12 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Ditto on not needing the friction control.
My Son Kris pulls the exact same trailer as you with a 2004 Ford Excursion without any sway problems.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~
CB Family Fleet
Butch&Barb 13CedarCreek~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 11 Laredo
Devocamper
West Haven CT
Posted: 06/13/12 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Part of the idea of the dual cam system is that you can back up without having to do anything to it where the friction type always say to remove them before backing up from what I recall from our TT days .only use one or the other the dual cam worked well for us for years on a 31 foot TT with a short bed TV.
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
Ramblin Recks
GA
Posted: 06/13/12 10:43am Link  |  Quote  |  Print  |  Notify Moderator
You will not need anything other than the Reese Dual Cam. I have had one for 4 years without a "hitch".
George and Ann
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO,4x4,3:73, Dual Cam Hitch
2008 Keystone Springdale 291RK Retired Army, but still working....until 2015
dodge guy
Bartlett IL
Posted: 06/13/12 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Very,very similar setup, No need for the friction swaybar. just make sure the DC is setup perfectly!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
djgarcia
Northern, Ca. , USA
Posted: 06/13/12 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
No! the friction sway bar will interfere with how the Dual Cam sway control operates. The dual cam sway controls are designed to work in tandem. i.e. depending on which direction the trailer is swaying, one DC sway bar will work against the other sway bar resulting in stabilizing the trailer in a straight line. This stabilization action is critical when you swerve in the event of a pending accident.
Dick
djgarcia@earthlink.net
Ron Gratz
full time RVer
Posted: 06/13/12 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
djgarcia wrote:
---The dual cam sway controls are designed to work in tandem. i.e. depending on which direction the trailer is swaying, one DC sway bar will work against the other sway bar resulting in stabilizing the trailer in a straight line.---
That is not correct.
The DC bars do not "work against" each other.
Ron
dodge guy
Bartlett IL
Posted: 06/13/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Ron
I think he may have his explanation a bit wrong. I think he meant that while one bar is on one side of the cam the other bar is doing the same thing but in the opposite direction.
 > Reese Dual Cam
