jambro
Pittstown, N.J
Today I started to clean my awning which is vinyl. It has'nt been cleaned in about a year,so it was pretty dirty. I was spraying on some of that reliable 1 cleaner which works fairly well, when my wife came outside with one of those Mr. Clean magic erasers.
Holy Cow! my awning looked like it was brand new. That little sponge took off all of the grime and mildew like nothing I've ever seen.
Never again will I buy that expensive awning cleaner.
The only bad thing is you can't use it on fiberglass as it is abrasive.
Jambro
2000 Jayco 3110 rlts
2000 F-250 Short Bed CC Auto PSD W/ Banks exhaust & Hypertech Supertuner
Tat2
Indiana
My daughter brought me some of those, and I can't say enough about them! I now refer to Mr. Clean as "Mr. Wonderful"!
[blue]Tat2 (Lynn) :B
[red]Mat-E (Phil)[/red] :W
[green]Mattie (Dog)[/green] :Z
[purple]Tattoo (Cat)[/purple] :C
Note: Due to invalid formatting, all formatting has been ignored.
sharrlan
chino,ca
Wouldn't leave home without them. One of the first things I put in our tt.
DYLANSDAD
Biddeford, Me, USA
Jambro, if they are to abrasive for fiberglass, why are you using them on your awning.
DYLANSDAD
2002 DODGE 1500 4X4 QUAD CAB
2003 CHEROKEE 275L
jambro
Pittstown, N.J
Well I did the first thing my wife told me to, which was to test it in an inconspicuos area. After doing a small portion of the awning and seeing how it rinsed right off I figured it would be safe.
But, when I go camping next week and all that's left of my awning is a roller tube I'm sure my wife would say " I told you not to clean the awning with that"
It says on the package contains mild abrasives which is why it should'nt be used on fiberglass and it also did not take any of the color off of my awning.
Dually Diesel
Wisconsin. USA
For the past several years I have taken the lazy man's way of cleaning the awning. First I mix some zip-wax and water, Brush onto the awning and then roll it up, Wait for about ten minutes and open awning and rinse off. Works great for me.........
F350XLT/CC/Dually/PSD/Auto/4X4/3.73/ Pulling a Sunnybrook 31BWFS Double Slide with all options
bluenote
Michigan
A moderate mixture of Simple Green and water cleans the awning really well too.
2001 Silverado 2500HD LS CC/SB Duramax/Allison Indigo Blue
2004 Cedar Creek 31LBHBS 5er
Our Team
Rallies Attended: 3½
cabanaman
middleburg florida
DYLANSDAD IS YOUR AWNING FIBERGLASS?
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.
2007 Open Road 378SA4S-5 quad slide.
august-alberta
Cold Lake, AB, Canada
I've used those Mr. Clean Magic sponges on everything, and I mean EVERYTHING including getting the bugs off the front of the trailer. Cleanest trailer in the park this weekend! Work great on black marks on the vinyl floor to rub marks inside the fridge. Don't even ned the elbow grease!
Hino Hauler
Hamilton
Do be careful using anything that is abrasive, sure it will clean well, but it also leaves minute scratchmarks which will allow a quicker build up of dirt and grime.
You are much better off using something like simple green or a citrus based cleaner. It might be a little harder and slower but will actually leave a cleaner surface.
Hino Hauler
