RV.Net Open Roads Forum: Travel Trailers: Mounting Generator To Rear Bumper Of TT
 > Mounting Generator To Rear Bumper Of TT
Morky
Newfoundland, Canada
Posted: 07/28/04 03:01am Link  |  Print  |  Notify Moderator
I have a new Cherokee 27L TT. I am considering making a aluminum checkerplate enclosure and mouting it on the rear bumper to carry my Honda 3000i generator. It is just to heavy to be lugging around any more. Anyone else have this done? Are there any weight concerns should I have by doing this?
bantam1960
Western USA
Posted: 07/28/04 03:16am Link  |  Print  |  Notify Moderator
Adding 150lbs+ to the rear of your tt will increase the likelihood of sway, assuming your frame can handle the additional weight bouncing up and down at the rear.
Whupdeedo
NE Ohio
Posted: 07/28/04 04:06am Link  |  Print  |  Notify Moderator
bantam1960's correct. Most TT bumpers are designed to withstand rear impact, not support loads. Also, when you put weight on the extreme rear of the TT, you certainly have reduced your tongue weight, probably much more than the generator + rack weight... Insufficient tongue weight can make for some scary, even dangerous, towing experiences.
Whupdeedo
'04 BRAVE 34D
V10 man
Tempe, AZ
Posted: 07/28/04 05:30am Link  |  Print  |  Notify Moderator
I saw 3 brand new trailers for sale at a Camping World parking lot. They all had Honda 3000's on the back bumper. Nice mount too with locks. I have 80 gallons of holding tank capacity(640 pounds) at the back of my trailer. 150 more won't hurt anything if your tanks aren't full.
1977 Ford F250 Supercab, 2002 Coleman Westlake
Lt46
Central Florida
Posted: 07/28/04 07:48am Link  |  Print  |  Notify Moderator
Morky,
Good question and one I can answer given I've just done this modification.
I mounted my Yamaha 2800i on a steel, welded frame made out of 2" L brackets. The bottom is an open mesh grate. The entire frame weighed in the 20+ lbs. range, add the 64 lbs. of the gen. and the 10 gals. of gas carried and I was in the vicinity of 150 lbs. hanging off the back of my TT.
I was leery of hanging that much weight on the bumper so, I had a friend weld 2" C channel (roughly 2' long) extending from the bottom of the 4" bumper to mid trailer, along the frame rail.
As far as handling went; It was noticeable! Not uncontrollable, but noticable. First, I had to redo my hitch set-up in order to have TT and TV level, secondly, too offset the loss of tongue weight, I shifted my packing arrangement to have all heavier items, forward.
The end result was satisfactory in regards to pulling the TT however, as said before, I could "feel" the rearend of my TT. Not as in sway (tough to describe) but suffice to say...it felt different.
FWIW: I use the Reese Dual Cam anti sway.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
2lMan
Brewer, ME
Posted: 07/28/04 05:55pm Link  |  Print  |  Notify Moderator
I have done this mount with my generator. The bumper of my trailer is reinforced more than some others I have seen. It is mounted with three pieces of square tubing, joining to the bumper either with a receiver tubing or with U-bolts.
The tongue of my trailer is pretty heavy to start with, so I was not concerned about removing some of the tongue weight.
2003 GMC Yukon XL 2500 8.1L 4.10 Axle - 2002 Sprinter Quad Bunkhouse
Home is where you bring it!
DFD536
GRASS LAKE, MI, USA
Posted: 07/28/04 07:10pm Link  |  Print  |  Notify Moderator
pm me with your e-mail address if interested, I have pics of the way I did it. Basically, fabricated a "hitch" on the back of the trailer (mounted to the frame, not the bumper), and inserted a generator tray with gen and fuel. As mentioned by someone else, there was a difference in handeling, but after adjusting the hitch, not a problem. I would not hang a generator off the bumper, just not designed for that kind of weight.
Dennis
The above is just my .02, which is normally only worth .01 (just ask my wife ">)
ENJOY YOUR RIG, LIFE'S TOO SHORT NOT TO ">
2004.5 Ram 2500 Cummins 6 spd ">
2002 Wildwood 30bhss
onan microquiet 4000
Got rid of a 2001 powerjoke for something with real power ">
rvlady
Sublimity, Oregon
Posted: 07/29/04 11:47pm Link  |  Print  |  Notify Moderator
Many manufacturers rate the carrying capacity of their rear bumpers. Ours is 150#--since we have two mounted spare tires we are that point already. I was thinking of this generator rear mount problem yesterday while following a vehicle with a fairly large electric wheelchair attached to their bumper hitch on a carrier. That wheelchair was definitely flexing up and down. Wondered what they felt in the vehicle. You also need to be careful of attatching a receiver to a lightweight frame--again the up and down flexing. There was a post awhile back about this--bent his frame.
Linda and husband Dave (retired US Army) W7DDW
Magic, Yellow Lab Female, born 18 July 2010. R.I.P., Jake!
2002 Arctic Fox 25R, Yamaha 2400i Generator
2003 DODGE 3500 SLT Quad Cab, 4x4, SRW, HO CTD, 3.73, 48RE, Jake Brake
