RV.Net Open Roads Forum: Tech Issues: Wasp's Nest... In the Heater
 > Wasp's Nest... In the Heater
millerak49
Fairbanks, Alaska
Posted: 02/28/10 02:59am Link  |  Print  |  Notify Moderator
here in alaska,we don't have to worry about mud daubers, never even heard of them. bought a new to us RV from Texas last fall and the furnace didn't put out as much heat as I thought it should. After checking some threads here, I checked for mud dauber nests, and found them in the intake and exhaust pipes of the furnace. While trying to clean them up a couple weeks ago, the intake nest fell into the fan housing. I had to remove the furnace to remove the large, frozen nest from the fan housing. IF I had tried to start the furnace, I am sure the frozen mud ball would have shattered the plastic fan blades. Thanks to this forum for providing the info I needed to check my furnaces. I will install an insect screen before spring to keep any other little critter out. THANK YOU! for helping me and saving us from further problems with our furnace.
dks
Mississauga
Posted: 02/28/10 06:30am Link  |  Print  |  Notify Moderator
I just installed the furnace screens last season after having a very small wasp nest. It seem like most of the problems seem to be in the furnace. Does anyone install the screens on their hot water or stove exhaust units?
bldrbob2
Fl
Posted: 03/02/10 09:29pm Link  |  Print  |  Notify Moderator
I cut the wirecloth to size and shaped it like the commercial one over the exhaust.The waterheater is just a flat piece fitted on the inside of the door over the opening.On the fridge I cut strips to line the inside of all the louvers.Everything seems to work so far.
BOB
nbounder
Arizona mountains
Posted: 02/28/10 07:49pm Link  |  Print  |  Notify Moderator
I have 'blown out' my furnace (compressed air through the external pipes )
a few times, assuming it would blast out any nests, but never saw a nest. I guess I just lucked out. Has anyone else tried that?
Nbounder
KG7DKF
bldrbob2
Fl
Posted: 02/28/10 07:48am Link  |  Print  |  Notify Moderator
I bought a foot of 1/8 " wirecloth and made screens for every opening I could find.Both furnaces, refer vent and waterheater.
John&Joey
Summer-North,Winter-South
Posted: 02/28/10 09:42am Link  |  Print  |  Notify Moderator
I'm going to do the same thing for my HW heater and fridge. Did you notice any issues with the HW heater? The commercial product is bowed out like the furnace one which has me wondering.
I'm assuming that the furnace one needs more open surface area to disperse heat due to the forced air coming out, so I went with the commercial made. This should not be the case with the HW heater in my mind.
LarryJM
NoVa
Posted: 03/03/10 05:01am Link  |  Print  |  Notify Moderator
BOB
If you want to protect the refer don't forget the elephant sized grate on the roof. Mine I don't think would keep Wasps or Dirt Daubers out, just elephants, squirrels, chipmunks, mice, etc. I don't worry about the refer or WH since normally what causes problems are spiders mucking up the gas jets/orfices with webs, etc.
Now Wasps and Dirt Daubers seem to like to get up into the furnace areas that are sometimes inaccessible w/o removing and dissembling the furnace and build nests that block the air flow in the exhaust.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
