RV.Net Open Roads Forum: Class A Motorhomes: Cloudy headlight covers
RV.net
 > Cloudy headlight covers
Wienerbago
Boyce, VA USA
Posted: 12/09/03 02:39pm Link  |  Print  |  Notify Moderator
Just had the MH in the shop for state inspection sticker and it barely passed because of cloudy plastic headlight covers. I was told that this is a big problem with older MHs. I was told by inspector that you can buy a plastic cleaner at Wal-Mart and restore the brightness. Unfortunately, I didn't have pencil to write down name of the product. Does anyone know of such a product or have other solutions to the dim headlight probme. Any help will be appreciated since I don't want to pony up $200 plus for a couple pieces of plastic.
WinnieElante93
wdbates
high desert So CA
Posted: 12/09/03 03:03pm Link  |  Print  |  Notify Moderator
wash the crap out of them with ajax, then buff them out with white rubbing/cleaner compound.. did this to alot of used cars in the desert due to sand damage...bates
Geneva & Warren
04 34m expedition ISB300/6speed
Autoturbine 4040/afe/TS 2110303 tuner
Oak hills CA
amore
Posted: 12/09/03 03:11pm Link  |  Print  |  Notify Moderator
I just went on line an looked up PLASTIC POLISH and found a bunch. One that stands out is a Maguiar Product Plastic Polish another one that I have used is Novus. It's a two part part product, get #2 and #1, if you can find it. You might go on line as I did.
amore
Rich & Vickie & spoiled Yorkies
Turc
Summerfield, Fl
Posted: 12/09/03 03:47pm Link  |  Print  |  Notify Moderator
I bought some Plexiglas cleaner, I use it to clean the windshield on my golf cart. they sell this at most auto parts stores. It works just great, will restore glass to original.--jt
JERRY & FREDDI
2003 DUTCH STAR
Jeep Liberty
"Hanna" our beautiful Vizsla
JohnnyT
Goshen New York
Posted: 12/09/03 04:00pm Link  |  Print  |  Notify Moderator
I think there are two kinds of cloudy plastic problems... The advice I have seen would certainly work with the kind of cloudiness associated with abrasion such as would be caused by a sand storm but what I think your talking about is the UV yellowing that occurs with plastic not sure how to cure that but I am thinking that attempting to polish or rub it out might make the problem worse There is a company call Janvil that specializes in plastic restoration compounds Scratch Polish There is also another company that offers products for plastic restoration Called Superior Products Superior Restoration A call to either or both might prove productive..
Good Luck!
JohnnyT
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee
M&G Brake & Break Away
Blue Ox Aventa II Tow bar
n5sgo
Catoosa OK.
Posted: 12/09/03 04:20pm Link  |  Print  |  Notify Moderator
What is used on some commercial aircraft is "Meguires Mirror glaze" to remove the yellow and polish the scratches out.
Lee
Lee & Marilyn
1989 Foretravel #15604
FMCA F291508
2001 Wrangler
3208 Cat 4 speed
http://f1.pg.photos.yahoo.com/n5sgo
2cyber71
Pennsylvania
Posted: 12/09/03 04:22pm Link  |  Print  |  Notify Moderator
Lee
I use Meguires Mirror Glaze...It works ok on my Bass Boat's Windshield but it will not help the deep scratches...It's expensive too....I still use it...
cyber
2007 Itasca Ellipse 40FD
Lucy 4 yr old Lakeland Terrier, 6-1-05
Gatlinburg, RV Campsite-Most recent trip
DLMT
The coast
Posted: 12/09/03 04:29pm Link  |  Print  |  Notify Moderator
Does anyone know if any of these products will work on high end plastic lensed(iridium?) sunglasses? I have a pair of Maui Jim's about $130.00 and even though you use the special dust free cloth and spray cleaner they still scratch. They are to the point of cloudy now.
Thanks
DLMT
jwmII
out west
Posted: 12/09/03 04:54pm Link  |  Print  |  Notify Moderator
Went thru this on my Windsor. Was like trying to drive with candles out there. Nothing in the way of polish or cleaner would work. I have enough of that crap around here to hold a yard sale for it alone. I finally called Monaco and they gave me their suppliers name and I had to bite the bullet and ordered new headlights for the coach. I suspect that is what everyone who has this problem will need to do. This problem is present on older cars and trucks as well, and a lot of these coach builders are using or have used the same parts in past models. Jack.
fredbob
bloomfield hills mich. usa
Posted: 12/09/03 05:13pm Link  |  Print  |  Notify Moderator
Weinerbago Most all recent headlight systems for RV's have been adapted from automotive headlights. From my background as a supplier of injection molded headlight assemblies I know that 90% of said assemblies are produced from Polycarbonate with a special silicon hard coating overlay of about 10 thousanths. The problem in trying to ressurect a light lens to like new is that the Polycarb material of which it is made is not very resistant to the sun and it yellows--sometimes all the way thru. When you try to polish the surface you end up with a mess trying to get through the hard silicon , and the if you luck out and get it all off you still have yellowed plastic to deal with. I have tried rubbing out on a number of old headlight lenses with very poor success. You can thank the DOT for the "anti-scratch". specs. on all headlights. To get it like new ,unfortunately you'll have to buy new. Fredbob
