RV.Net Open Roads Forum: Tech Issues: awning disaster
RV.net
 > awning disaster
penukleman
Upatoi,Ga,USA
Posted: 04/09/04 05:46pm Link  |  Print  |  Notify Moderator
Well...I did it..I left my awning up last nite to let it dry..a huge windstorm came up during the nite and destroyed the brackets and other hardware. Does anyone know of a repair kit for Imperial 8500 made by AE systems?
The roller and vinyl awning are not damaged.
itsasecret
Washington DC USA
Posted: 04/09/04 06:19pm Link  |  Print  |  Notify Moderator
But are they dry ?
2004 Mandalay 40B , four slides, 350 Cummins/Freightliner.
tech47
Grosse Pointe Woods Mi. USA
Posted: 04/09/04 06:22pm Link  |  Print  |  Notify Moderator
Here is a link to replacement parts.
Awning Parts
ROBERT & VIRGINIA HAMILTON
2006 Dodge Ram 3500 Dually H.O. Cummins Quad Cab,Auto,4WD,3.73 Posi.
2004 Cardinal 33TS LX Triple Slide Fifth Wheel
U.S. AIR FORCE(Retired)
Rally Attendance "3"
Our Homepage
Yeti Shaman
Cape Canaveral, FL, USA
Posted: 04/09/04 06:29pm Link  |  Print  |  Notify Moderator
If you have a RV dealer with parts store, nearby , go there with your bent broken parts
If you have the intstallation manual for awning it will be helpful to know the correct name for parts needing replacement
Otherwise try
http://www.pplmotorhomes.com/parts/rv-awnings/a-e-awning-parts.htm
http://www.pplmotorhomes.com/parts/monthlyspec/1aw_repr.htm
tech47
Posted: 04/09/04 06:47pm Link  |  Print  |  Notify Moderator
Which is the link I posted.
penukleman
Upatoi,Ga,USA
Posted: 04/10/04 10:58am Link  |  Print  |  Notify Moderator
Thanks for the information Tech47...I just saved myself around 500 dollars by not having to order the entire awning....just needed the repair parts that are around 300 dollars...
I think I can do the work myself...I hope.
russ in ga.
Capt-Ron
Down South in the Palmetto State
Posted: 04/10/04 02:26pm Link  |  Print  |  Notify Moderator
My awning arms got bent during a bad storm and I took the parts to the local RV dealer. They went out back to the junk pile and came back with the parts that I needed that where in great shape and charged me $10/piece.
Capt Ron
2003 F-350 CC, LB, 6.0L PSD, 6SP Manual, DRW, Kelsey-Hayes 81740C hydraulic brake controller.
Paralleled Honda Eu2000i's
No Longer Full Timing After 5 Years!!!
penukleman
Upatoi,Ga,USA
Posted: 04/11/04 09:07am Link  |  Print  |  Notify Moderator
Our local RV place is new to town, and has not established himself enough to have any spare parts around, He,did say he would help me find some that I needed..
thanks for the help.
 > awning disaster
