RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: Camping ice cream
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > Camping ice cream
Camp Cooks and Connoisseurs Related Tips
ljguidry
Butte, MT
Posted: 09/06/04 07:33pm Link  |  Print  |  Notify Moderator
In PM correspondence with Grillmeister, I shared some experiences about conducting a workshop for chemistry teachers in the Philippines. The lesson was to demonstrate just what he had posted on a method of depressing the freezing point of liquids.
In our workshop we made ice cream, using a gallon and a quart sized ziploc bags. The teachers went totally ballistic and were looking forward to presenting this contextual lesson in their classrooms. Grillmeister urged me to post the recipe.
For all you cooks, the recipe is below. For all of you teachers cum campers, I have also included the procedure for doing the experiment. This recipe was made several times, both as plain vanilla and with added tropical fruits. It is a great project for kids to do while out camping -- they can learn a great lesson and get to eat the "fruits" of their labor as well!
We hope you all will try this and enjoy this.
Freezing Point Depression and Colligative Properties
Materials
· 1/2 cup milk
· 1/2 cup whipping cream (heavy cream)
· 1/4 cup sugar
· 1/4 teaspoon vanilla or vanilla flavoring (vanillin)
· 1/2 to 3/4 cup sodium chloride (NaCl) as table salt or rock salt
· 2 cups ice
· 1-quart ZiplocTM bag
· 1-gallon ZiplocTM bag
· thermometer
· measuring cups and spoons
· cups and spoons for eating your treat!
Procedure
1. Add 1/4 cup sugar, 1/2 cup milk, 1/2 cup whipping cream, and 1/4 teaspoon vanilla to the quart ziplocTM bag. Seal the bag securely.
2. Put 2 cups of ice into the gallon ziplocTM bag.
3. Use a thermometer to measure and record the temperature of the ice in the gallon bag.
4. Add 1/2 to 3/4 cup salt (sodium chloride) to the bag of ice.
5. Place the sealed quart bag inside the gallon bag of ice and salt. Seal the gallon bag securely.
6. Gently rock the gallon bag from side to side. It's best to hold it by the top seal or to have gloves or a cloth between the bag and your hands because the bag will be cold enough to damage your skin.
7. Continue to rock the bag for 10-15 minutes or until the contents of the quart bag have solidified into ice cream.
8. Open the gallon bag and use the thermometer to measure and record the temperature of the ice/salt mixture.
9. Remove the quart bag, open it, serve the contents into cups with spoons and ENJOY!
Explanation
Ice has to absorb energy in order to melt, changing the phase of water from a solid to a liquid. When you use ice to cool the ingredients for ice cream, the energy is absorbed from the ingredients and from the outside environment (like your hands, if you are holding the baggie of ice!). When you add salt to the ice, it lowers the freezing point of the ice, so even more energy has to be absorbed from the environment in order for the ice to melt. This makes the ice colder than it was before, which is how your ice cream freezes. Ideally, you would make your ice cream using 'ice cream salt', which is just salt sold as large crystals instead of the small crystals you see in table salt. The larger crystals take more time to dissolve in the water around the ice, which allows for even cooling of the ice cream.
You could use other types of salt instead of sodium chloride, but you couldn't substitute sugar for the salt because (a) sugar doesn't dissolve well in cold water and (b) sugar doesn't dissolve into multiple particles, like an ionic material such as salt. Compounds that break into two pieces upon dissolving, like NaCl breaks into Na+ and Cl-, are better at lowering the freezing point than substances that don't separate into particles because the added particles disrupt the ability of the water to form crystalline ice. The more particles there are, the greater the disruption and the greater the impact on particle-dependent properties (colligative properties) like freezing point depresssion, boiling point elevation, and osmotic pressure. The salt causes the ice to absorb more energy from the environment (becoming colder), so although it lowers the point at which water will re-freeze into ice, you can't add salt to very cold ice and expect it to freeze your ice cream or de-ice a snowy sidewalk (water has to be present!). This is why NaCl isn't used to de-ice sidewalks in areas that are very cold.
Stolen from unknown author
Ellen & Loyd Guidry
Suzie2 and Ozzie2 (Brother/Sister Scottie/White Highland Terrier mix who don't know they're "D-O-G-S"-(We recently lost Suzie1 and Ozzie1 - BUMMER!!)
Grandkids every chance we get
Butte, MT
GMC 1-TON DURAMAX
36 ft. Carriage Carry-Lite
Bonnie E
South Jersey Pines
Posted: 09/06/04 07:39pm Link  |  Print  |  Notify Moderator
Thanks for the lesson. we have done this before but will incorporate the lesson next time.
2004 Jayco 25e traded in
2007 31RQS Outback Sydney maiden voyage GBIV
2005 3/4 ton... 8.1 Sub..."THE BEAST"
Assateague Island 2004 Survivors
ASSATEAGUE SURVIVORS 2005
Grillmeister
Iconoclast
Good Sam RV Club
Posted: 09/06/04 08:10pm Link  |  Print  |  Notify Moderator
GREAT!! Post
I can't wait to try it. Also thanks for the detailed explanation at the end describing why this all happens. I love this kind of stuff. I just learned why in my ice chest experiments things got off to a slow start until melted water was present.
Thanks again for a terrific recipe.
Show me the GRILL and STAND BACK!!!!
Trukinbear
LA
Posted: 09/06/04 08:21pm Link  |  Print  |  Notify Moderator
And to think I paid $14.95 for our ice cream churn, I could have used ziploc bags all along. ROFL ;-)
We use the churn all the time, summertime and home made ice cream just go hand in hand.
INSAYN
NW Oregon
Posted: 09/07/04 12:19am Link  |  Print  |  Notify Moderator
I put my ingredients in a small Dutch Oven and put this into a cooler filled with ICE, and rock Salt. Takes about an hour to make ice cream if you stir it every ten minutes.
Be sure to use any flavor of instant pudding mix to give it some great texture.
INSAYN
1997 F350 CrewCab PSD 4x4, auto.
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, 2005 40HP Yamaha 2-stroke O/B.
dipstick
Everywhere more than anywhere else
Posted: 09/14/04 02:29pm Link  |  Print  |  Notify Moderator
Sometimes whipping cream is not readily available - can you use all milk instead?
Founder - Procrastinators Anonymous
(we haven't had a meeting yet, but we're thinking about it)
ljguidry
Butte, MT
Posted: 09/14/04 06:39pm Link  |  Print  |  Notify Moderator
I'm not sure, but I think you probably could use canned, evaporated milk. Please give it a try and let us know how it turns out!
Mukilteo
Mukilteo, WA
Posted: 09/15/04 05:12pm Link  |  Print  |  Notify Moderator
great topic! We use coffee tins, one large and one small and the kids roll/kick/toss it.
I USED to have this great recipie for ice cream that didn't need churning, just whip and put in the freezer, and I have lost it! ugh!
My son will love the explination, he is quite science minded - thanks!
Happiness is Being Married to Your Best Friend ~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*
Cruzette
Santa Cruz, CA
Posted: 09/16/04 09:19am Link  |  Print  |  Notify Moderator
Ice Cream in a Can
Using a small and a large coffee can you can recreate an ice
cream maker.
approx. 30 Minutes. Makes 4 servings.
1 egg
1/2 cup white sugar
1 tablespoon instant vanilla
pudding mix
1 cup milk
1 cup half-and-half cream
1 teaspoon vanilla extract
1 cup rock salt
1 pound crushed ice
In a medium bowl, whisk together the egg, sugar, instant pudding, milk, half and half and vanilla. Pour the mixture into a 12 ounce size coffee can. Cover the top with plastic wrap, and then the plastic lid. Place the filled coffee can into an empty 34.5 ounce coffee can (the big ones). Fill the empty space with crushed ice, sprinkle generously with rock salt, and cover with the plastic lid.
Roll the cans around on the floor for about 20 minutes.
Note: If the center of the ice cream is still soft, place the containers in the freezer to harden.
Mukilteo
Mukilteo, WA
Posted: 09/16/04 11:32am Link  |  Print  |  Notify Moderator
Awesome! The kids love making this
You wouldn't happen to have the one that doesn't need churning but you put right in the freezer and stir twice an hour, do you?
 > Camping ice cream
