RV.Net Open Roads Forum: Technology Corner: DTV conversion
 > DTV conversion
Technology Corner Related Tips
fpowers5555
Michigan
Posted: 11/09/08 05:47am Link  |  Print  |  Notify Moderator
With the Feb 09 digital conversion for TV antennae, has anyone hooked up the required converter yet? I have (most do) an amplifier between the external antenna and the TV. Does it need to be connected before the amp?
Wadcutter
IL
Posted: 11/09/08 06:01am Link  |  Print  |  Notify Moderator
This has been covered ad nauseam in the Technical Forum. If you do a topic search you'll find pages of threads on the topic. A lot of us have already connected our converters. The converter goes in-line just before the TV just like if you connect a DVD/VCR. It's not difficult.
Camped in every state but Alaska
wantsalife
Home
Posted: 11/09/08 06:18am Link  |  Print  |  Notify Moderator
Not sure how true this is... hopefully someone will be able to weigh in and shed some light... Does the outside antenna have to be the digital version?
Dennis M M
Geneva, IL
Posted: 11/09/08 06:37am Link  |  Print  |  Notify Moderator
My understanding is that it does not need a digital antenna, have not tried mine yet, but what I have read says existing batwing antenna will work fine.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'05 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro;
Optima Batteries
Our Travel Blog - A New Adventure
fla-gypsy
North Florida
Posted: 11/09/08 06:44am Link  |  Print  |  Notify Moderator
Hook the converter between the amp and the tv, nothing else is needed. I have been using mine for 6 months
Camping Photos
Wadcutter
IL
Posted: 11/09/08 07:12am Link  |  Print  |  Notify Moderator
If a person is in the business of selling antennas then they'll tell you that you need a new antenna. Your current antenna will work fine. The frequencies are the same it's just that they're going to be broadcast in digital form instead of analog. Unless you want to help an antenna saleman send his kid thru college just leave your current antenna as is. Your antenna doesn't know the difference between a digital signal and an analog signal.
Chris
Shelter Bay, Wa
Posted: 11/09/08 07:50am Link  |  Print  |  Notify Moderator
Nor does the amp know the difference! It is amasing with all the effort the government put into this conversion that they complete ignored the RV and Marine industries. I got the two coupons for the house and installed one on the boat and one in the trailer. Taking both boxes South for the winter in the trailer. Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
balvert
Windsor, Ontario
Posted: 11/09/08 11:14am Link  |  Print  |  Notify Moderator
My original Wineguard antenna works great on the digital channels. The old anolog channesl are snowy and switching to the digital channel of the same station comes in crystal clear. The antenna on the top of your RV will work just great.
Casey
Casey & Karen, Border Collies, Polly & Babe
04 Newmar Mountain Aire 34RDCK with tandem duals & XPS Ribs, Pullrite 25.5K Super 5th, MorRyde, Solar, RotoChoks
03 Dodge DRW Sport, Cummins, 4.10, 6 spd, MBRP SS Exhaust, Jacobs E-Brake, Tire Sentry, BrakeSmart
bearsnob
Oregon
Posted: 11/10/08 12:30am Link  |  Print  |  Notify Moderator
I highly recommend the DTV Pal converter box if you haven't bought one yet. My guess is the standard amplified RV antenna is better than most of the so-called DTV antennas out there.
Bill, Carol & Striker The Cat
2005 Everest 323k
1989 Ford F-350 Crew Cab, 460, 5 spd, 4.30 axle
Everest owners: check out the Everest Owners Club.
Make a small loan, Make a big difference: Kiva.org
wantsalife
Home
Posted: 11/10/08 02:01pm Link  |  Print  |  Notify Moderator
No need for the sarcasm... I was just asking an honest question. Thanks for the actual info though. Camp Well!
 > DTV conversion
